Old 12-04-2012, 04:46 PM   #1
jlwilliee's Avatar
Windgard Wingman????
I`m thinking about buying a windgard wingman,but I want to get some real reviews of them.You only get their reviews on their site.Be honest and detailed.It would be helpful for,area you live in and things like trees,and anything else that would be helpful...Thanks in advance.
jlwilliee is offline   Reply With Quote
Old 12-04-2012, 04:51 PM   #2
sail2liv's Avatar
Get it
Best $20-30 you will spend and the easiest thing you will ever install on your unit.....good luck only thing that might be better is the OXY shower head.....but I watch TV a lot more than I bathe.....
2011 Silverado 2500HD 6.0 Gas 3.73
2013 Flagstaff 8524 RLWS
1978 Cape Dory Ketch
sail2liv is offline   Reply With Quote
Old 12-04-2012, 04:57 PM   #3
Terier's Avatar
I have a regular campground & site at the beach that I visit often. The difference between having the Wingman is with over-the-air stations is that the picture is clearer and doesn't break up. I don't think I get any more channels but I haven't really put much effort into searching for the perfect antenna location either.
Old 12-04-2012, 04:57 PM   #4
I as well as several fellow campers I know have installed the Wingman and yes it does work. You do have to aim it toward the strongest signal with the help of the signal strength meter on your tv. I would definately get one or look at installing the Jack antenna which I've read good things about.
Old 12-04-2012, 06:36 PM   #5
Phat Phrog Phlunky
essness's Avatar
The jack antenna allows you to aim it but doesn't need to be cranked up or down.
I've had experience with both and you cannt go wrong either way.
Scot, I am "that guy"
2014 Raptor 27FS
2014 Ram 1500 Laramie
Days camped in 2013 = 30 final.
Days camped in 2014 = 27 final.
igkra.com
essness is offline   Reply With Quote
Old 12-04-2012, 07:03 PM   #6
lindy's Avatar
Had the wingman and saw NO real difference. Bought a JACK antenna replacement head and saw a BIG difference.
2012 Winnebago "Journey To Insanity" 40U
2008 Dakota Sport 4x4
2004 Subaru Baja - DW's
2006 Honda Shadow Aero - TOAD for now.
F.R.O.G. member
lindy is offline   Reply With Quote
Old 12-04-2012, 07:14 PM   #7
3 Happy Campers's Avatar
I installed one right when they came out.
They advertise you will double your channels.
Before installing I received 6 over the air digital channels while parked in my driveway.
After installing (and without even raising the antenna) I was able to pull in 20.
After deleting the Spanish channels & was getting 15 so it worked better than advertised.
Just remember, itís not a fix all cure. I have set up in a half dozen places where no signal could be found at all.
Name:	Batwing Winegard.jpg
Dave, Judy & Daisy May
Perkasie, PA
2010 Sierra 356RL
2011 Silverado 2500 4WD, LT, Ext Cab, LB
Duramax 6.6L V8 Turbo Diesel
Allison 1000 6-Speed Automatic Transmission
3 Happy Campers is offline   Reply With Quote
Old 12-04-2012, 09:29 PM   #8
Herk7769's Avatar
Check out the product review forum on this device.
It gets a "Herk's Thumb's Up"
HAM CALLSIGN - KC3FFW
Old 12-04-2012, 09:36 PM   #9
bend302's Avatar
I agree.
I had to bend one of the metal wings a bit as it caught under the AC cover when closed and would catch when trying to crank up. Otherwise very good results.
Bill
Life is a journey, not a destination.
2005 Georgetown 359ts
Bill & Virginia, Kentucky
Nights camped in 2011...78 , 2012...73,
Nights camped in 2013...123, 2014 ...101
bend302 is offline   Reply With Quote
Old 12-04-2012, 09:38 PM   #10
sfrye5853's Avatar
X2
2005 Ford Expedition 5.4 4x4
2012 Tracer 3150BHD
sfrye5853 is offline   Reply With Quote
Old 12-05-2012, 12:17 AM   #11
I replaced the OEM older version winegard with the Jack Digital HDTV Antenna as one of my first MODs on our new Sabre. At first, I was going to add on the "Wingman" to help with the UHF-HD, but after seeing a demo at an RV show I decided to spend a little more and try the Jack Digital. I did install the Wingman on our previous TT and got good results with that as well.
I only have one piece of data to share...the "before and after" test on the side of my house produced ~ 11 more channels using the Jack Digital Antenna. btw..it was a very easy unstall, but not as easy as the Wingman. I don't have any actual data comparing reception between the Wingman and Jack digital, but my feeling is that the Jack does a little better.
I also use the King Control Dig TV Finder which helps locate th strongest digital signal prior to doing a channel scan
Just rotate the antenna and peak the signal strength. Works great...especially in fringe areas
Hop this helps.
Cathy & Jeff
Midland, Michigan
2020 Cedar Creek 34IK / 2019 Ram3500 CID
SimchaSabre is offline   Reply With Quote
Old 12-05-2012, 01:08 AM   #12
J_KHawthorne's Avatar
I made a hurried and "last-minute" installation of this product before our trip up into the Pacific NW and Canada this past June. It was a good investment.
I really didn't know how good it really was until we returned home and I got to test it from our farm which is situated ~50 miles NE of Kansas City, MO.
Our house TV runs off a gigantic antenna on a 30 foot mast that runs through an RCA amplifier.
The Wingman enabled my standard trailer antenna to duplicate the performance at the house!!!
Excellent value in this product and a cinch to install!
Highly recommended!
Jim & Kathy
2012 Crusader 290RLT TE, TrailAir flex pin: 2012 Toyota Tundra 5.7 SR5 Dbl cab 4X2 Tow, 4.30 gears, RideRite air, TRD cold-air induction & dual exhaust: Reese 16K Slider: TST tpms
Miles towed to date: 26,890; Nights camped; lost count!
J_KHawthorne is offline   Reply With Quote
Old 12-07-2012, 02:31 PM   #13
jlwilliee's Avatar
Thanks for all of the help. I think after reading these post I have made the decision to go ahead and spend a little more and get the Jack Digital.
Old 12-07-2012, 02:32 PM   #14
jlwilliee's Avatar
Now!!! Where to get one???
Old 12-07-2012, 03:26 PM   #15
dretired's Avatar
the wingman helped pull-in more stations for me and easy to install
2014 Crusader 325 TE....2012.. F 250.. Supercab XLT, 4x2 , diesel....days camped 2011 ... 28.... days camped 2012...115 ... days camped 2013...155...2014...171 and counting
dretired is offline   Reply With Quote
Old 12-07-2012, 03:29 PM   #16
Herk7769's Avatar
http://www.campingworld.com/shopping...FY-d4Aod82IAyg
or you can use the 29.99 Wingman (on sale for 25 bucks).
http://www.campingworld.com/shopping...-wingman/44021
