Old 08-04-2018, 03:46 PM   #1
larry2c's Avatar
Window prop
We have two windows in our TT that are hinged at the top and have a hold open rod that only lets them be open about 8". Today I made a pair of longer window props that will let them open "all the way". This is an interim prop to see if it helps get more air in the TT and if it works I will likely make something more elaborate. The current version is just a 32" piece of 1/2" PVC with a notch in one end that grabs the frame around the window.
Just thought I'd share and also see if anyone else had come up with something clever to do the same thing.
I just want to be outside!!!
'17 Salem Cruise Lite 210RBXL
'11 F150 5.0
Two shedding mutts
larry2c is offline   Reply With Quote
Old 08-05-2018, 07:42 AM   #2
SeaDog's Avatar
good idea should would increase ventilation, if the hold open rods are not attached at the top and bottom is a strong gust of wind has a much greater sail area to affect with the window open that far and may lift it causing to it to slam back down, the affected sail area is lessened with the window at more of an angle. Just something to consider.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 08-05-2018, 05:15 PM   #3
larry2c's Avatar
SeaDog - that's why this is a preliminary version and I was asking if others had done something more clever. I'm thinking I may fabricate some brackets that will let me put detent pull pins in so that it can't "get airborne". Driveway testing says the airflow is much better.
'11 F150 5.0
Two shedding mutts
Old 08-07-2018, 06:03 PM   #4
My interest would not be to open the window a whole bunch, but rather close it half way from the standard opening. My windows have a flat bar you push out until you reach the indent to hold the window open. But if I want to close the window half way there is nothing to hold the window. I have resorted to using double faced tape wrapped around the flat bar as a way to prevent the window closing completely. But the tape does come off at times. The reason I want to close the window is when it rains with a wind. Rain comes in when opened fully. Trying to prevent this. Any ideas other than my idea?
Booboos is offline   Reply With Quote
Old 08-07-2018, 06:29 PM   #5
GLBCamper's Avatar
Just this last (hot) weekend I was lamenting that there wasn’t more airflow from those windows! I wondered why they didn’t put a magnet and have them function like the storage bay doors. I wonder if you could add something like that?
2016 EVO (Sonoma) ATS 201rd 24’ TT
2016 F150 4x4 Sport
GLBCamper is offline   Reply With Quote
Old 08-07-2018, 06:48 PM   #6
Great idea. I will try that....and I already have magnets that would work.
Old 08-07-2018, 07:06 PM   #7
GLBCamper's Avatar
Keep us posted (with pics!) would love to know how it works out.
2016 F150 4x4 Sport
Old 08-07-2018, 07:53 PM   #8
Just as confused as you
Scrapper's Avatar
I don't remember who it was but here is what another member made for his windows. If your worried about the bottom slipping out of the slot just drill a hole in the tab for a hair-pin clip or a twist-tie.
ID:	182586   Click image for larger version
Richard & Jill
Camping since 1989, seasonal since 2000
Scrapper is online now   Reply With Quote
Old 08-09-2018, 01:35 PM   #9
Magnets did not work since the bars are aluminum.
Old 08-09-2018, 01:40 PM   #10
GLBCamper's Avatar
Same as the storage doors. You would have to install one on the window frame and one on the side of the trailer.
2016 F150 4x4 Sport
window
