you may have to re-calibrate the shade. On the drivers side molding need to remove the 4-5 screws and behind there at the top there should be a blk button connected to 2 wires. this is the reset button and there are instruction on the Class A section Georgetown Motorhomes. Do a search and should pop up. i had that issue once and you need to reset in both engine running mode and also engine off mode.
Andrew & Donna Reyes 2012 Georgetown 378XL 2015 Ford Taurus & Our Baby Dachshund Cammie
