11-12-2011, 08:42 AM
Wintererizing
I have never winterized my Rockwood 8312ss. Can I just blow out the lines or is the anti-freeze necessary? Any instructional help would be great. thanks
11-12-2011, 08:57 AM
Personal choice. Some just blow out the lines, some just use anti-freeze and some do both.
When done properly any of those methods will do the job.
Gary & Trish
2011 LaCrosse 303 RKS Touring Edition : 2007 Flagstaff 206ST MAC Series
2010 F-250 XLT : FX4 : CC : SB : 6.8L V-10 : 4/10 Gears
2012 Nights Camped - 5
Lottery Non-Winner
Lots of opinions on winterizing. I will try to be brief and at the same time put forth an opinion on BOTH sides of the dry winterizing / wet winterizing process.
You can just blow out the lines with air.
Do not forget to open the "low point" drains.
Do not forget the "P" traps. You still need to pour a little RV antifreeze into those (sinks, shower/tub, toilet) or somehow make sure they have no water resting in them.
Do not forget to drain the fresh water tank.
Do not forget to drain the water heater (remove the plug and lift the pressure relief bail).
Some people use RV antifreeze and then blow out the lines (double sure).
2011 Georgetown 337
2009 HD FLHTCU
2007 HD FXSTC
11-12-2011, 10:06 AM
volunteer moderator
Peace!
Dan & Rita D
2008 Rockwood 2502 Ultra Lite
2004 5.3L Silverado 1500 ext. cab 2WD
Reese dual cam hitch, AirLift load levelers
53 days camping in 2010, 47 in 2011, 12 in 2012
| Thread Tools |
| Display Modes |
» Recent Threads |
» Online Users: 576 |
| 118 members and 458 guests |
| 2011sv264, 2lvrvn, 4bnabird, 4Jeeperz, Adony, adp1326, armcor02, ayotte, bayouboys, Bigmatt, bikeman911, bikendan, bka4tcu, bmcgee, bob213, Bob_Loblaw, boubou, Buffalohunter, bush, buzzmonster, Cccross3, cgreen1509, chevy02, cllecr, COcamper, crawford, cyclepuck, dashonthedash, dasimser, daw592, DDC, ddemme, DeeMax, dezolen, donn, Drmstx62, Dutch & Di, fast murray, Fire Instructor, forensicdeac, FreedomTracker, gb73071, gimp425, GlacierGus, greran, h20ski, hark582, Hilgy, hjmiberry, itat, Itsthetwoofus, J McClure, J R, JamesR, jasni, jimandjoyhamel, jjhwisconsin, JJL, jking, johnthecamper, jsutherl, jtstromsburg, Kirby, KRS, kwjeepxj, Mad4sax, manvel, Margaret, Marsh707, meatguy, michel, MikeT, Mnflyboy, MrAllen, mtfd515, mwilson949, ncgrl1, NO3putt, nowait, ohiobill, partime, patov6, Pawpod, peaeye, Phil1, Phil57, PHS79, punkaccountant, rgfenner, RJHuser, rkswyo, rmason8092, RockyMtnHigh, Rsgtivr6, sbond, Sg6923, SinkorSwim, sjones7246, Smithee, snackage, sprayking, Stedman1, steeleshark2, Steve7575, sundawg, Swinks, tentcamper1, Terier, thehamguy1, thom01, Tincup13, tking1866, troyt, VinceU, vp22er, Waterfowlwarrior, WestCoastRV'er, Westernflyer |
| Most users ever online was 1,025, Today at 01:04 PM. |
