Old 11-12-2013, 08:52 AM   #21
Wardell240's Avatar
Do most RV have have another drain other than the one with the anode attached ??
Wardell240 is offline   Reply With Quote
Old 11-12-2013, 09:08 AM   #22
NHFire 152's Avatar
As in low point drains? My Windjammer does. Door side near the rear of the unit. As far as hot water tank drains... I don't believe there is anything other than the plug (which may or may not have an anode rod attached to it).
NHFire 152 is offline   Reply With Quote
Old 11-12-2013, 09:32 AM   #23
Denver, CO
garbonz's Avatar
On the HW heater that is it, but there should be 2 low point drains under the unit that drain the hot and cold lines.
2017 Fuse 23T
Old 11-12-2013, 10:08 AM   #24
... but note that in most cases, while the low-point drains will drain a lot of the water, they won't get it all. Further steps are needed.
winter, winterize
