Old 10-01-2016, 06:33 PM   #31
You can buy a tire air chuck that clamps on to air adapter. Every tire shop uses them.
Dakota C Creek is offline   Reply With Quote
Old 10-01-2016, 07:16 PM   #32
Originally Posted by extxn View Post
No Camping World close to me up here in the Northeast Kingdom ~ bought the same thing at Wally World, about the same price.
These are the easiest, available on Amazon
https://images-na.ssl-images-amazon....1s6Fj1snuL.jpg
Darlingdoug is offline   Reply With Quote
Old 10-01-2016, 07:41 PM   #33
gwj123's Avatar
I have read here where a lot of you talk about pumping "the pink stuff" through your lines, but not to put it in the FW tank. I guess I am being dense here, but how do you pump it through your lines without using the pump from the FW tank?
2016 RAM Laramie 2500 CC 4x4 Cummins Turbo Diesel
2017 Forest River Wildwood X-Lite 254RLXL
gwj123 is offline   Reply With Quote
Old 10-01-2016, 07:44 PM   #34
With bypass valves. You isolate the FW tank entirely. You drain it (FW tank), thats it.
SidecarFlip is offline   Reply With Quote
Old 10-01-2016, 08:21 PM   #35
The OP states they do NOT want to use Pink AF,their Water pump will NOT be protected if they only use Air! Even though they state they have Never used the F/W tank or Pump,Water will still be Inside the Pump Chambers and it Will Freeze! Youroo!!
Old 10-01-2016, 09:39 PM   #36
Scubanut's Avatar
Originally Posted by DKRITTER View Post
I use a quick connect blowout plug like this and it's an easy job.
https://www.amazon.com/Camco-36143-B...ut+plug+for+rv
I hook it up to my shop air-compressor and set the regulator at 40psi and just keep opening valves starting high until only air comes out.
Drain the WH first and don't forget the outdoor shower if you have one and especially the toilet.
It takes a couple of beers.
Exactly how I do it! But being in Canada I also add the pink!
2012 F150 FX4 Crew 5.0 3.73 gears
2O12 Coachman Freedom Express 292BHDS (outdoor Kitchen)
Scubanut is offline   Reply With Quote
Old 10-01-2016, 09:42 PM   #37
Scubanut's Avatar
winterizing with compressed air
Buy a winterizing kit and install it, very simple to do. You attached the quick connects at the pump, there is a valve you rotate and instead of sucking water out of your fresh tank(which should already be emptied) you stick a hose into your pink stuff and as the picture shows turn your pump on and it will suck the pink through all your faucets. Start at the furthest and work back. Ensure you put your water heater in by pass so your not wasting 6 gallons of pink.
Name:	ImageUploadedByForest River Forums1475376473.878575.jpg
ID:	121879Click image for larger version
Name:	ImageUploadedByForest River Forums1475376487.786369.jpg
Old 10-01-2016, 09:56 PM   #38
Ford Idaho's Avatar
The lite drinks right out of the jug.
FW tank is bypassed as in the water heater.
I used two gallons.
Old 10-01-2016, 10:27 PM   #39
I haven't bothered with the pump. My Roo 19 went through 3 winters, -20 F and I had no problems.
If you're worried, you can hook up air to the AF line and, using LOW pressure, start the pump. The air will blow through the pump.
Your mileage may vary.
2011 Traverse LT, 3.6L, FWD
rockfordroo is online now   Reply With Quote
Old 10-02-2016, 11:32 AM   #40
If you use a bypass, the pipe from the tank to the pump is not winteryse!
Jonol is offline   Reply With Quote
winter, winterize
