Old 09-30-2016, 05:54 PM   #1
rp53's Avatar
winterizing with compressed air
I really don't like the pink stuff, would like to blow the water out just don't know how to do it. I know I will still have to put the pink stuff in the p-traps but how do you blow the lines out, is there an adapter that hooks to the city water intake? we have never used the fresh water tank.
sorry if this has already been asked
2017 Micro Lite 21FBRS
2014 Chevy Silverado dual cab 4X4 Z71
rp53 is offline   Reply With Quote
Old 09-30-2016, 06:01 PM   #2
coupevillefish's Avatar
Yes, there is an adapter. I have done it both ways but much prefer the air method.
You should be able to find the adapter at any RV center, probably in the Walmart RV section, and I assume, Amazon. Just keep your pressure at about 20 pounds and open one facet at a time. Of course, empty the fresh water and hot water tanks first.
It's really a two person job at least for us. One at the compressor and the other doing faucets.
coupevillefish is offline   Reply With Quote
Old 09-30-2016, 06:12 PM   #3
Flybob's Avatar
You just need one of these.
Blow Out Hose - Direcsource Ltd TS-N19 - Winterizing - Camping World
Be careful not to use too much pressure.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
Old 09-30-2016, 06:15 PM   #4
That looks like it could be done by one person. Mine is a simple cap with a nipple. I have to hold the air nozzle to it.
Old 09-30-2016, 10:49 PM   #5
Same for me, its much easier that way.
2016 Coachmen Freedom Express Liberty Edition 292BHDS
FRRVR is online now   Reply With Quote
Old 09-30-2016, 11:05 PM   #6
It is a little like wearing a belt and suspenders, but I blow out the airlines with my air compressor first then pump the pink antifreeze through. I bought one of those Wal-Mart plastic air connectors, but it broke right away. So, I drilled out the plastic air adapter and threaded in a spare quick-connect adapter to my air line. (Absolutely make sure that you have reduced the pressure on your air regulator so you don't blow out all of your water lines.) This makes it a one-person task. You have to run through less antifreeze to get it all the way through the system, since you are only pumping out air and not water; and you have winterized with certainty. Only takes a few minutes.
Velosprout
2014 F150 SCrew 4x4 Max Tow Heavy Duty Payload 3.5 Ecoboost 6.5' bed Ingot Metallic Silver
2015 Rockwood Roo 21SS
Velosprout is offline   Reply With Quote
Old 10-01-2016, 05:22 AM   #7
waiter21's Avatar
I have a couple of these, Camco makes them, sold by most RV places, walmart, etc.
https://www.walmart.com/ip/Camco-Blo...ingMethod=p13n
Although I've done it with compressed air, to me it adds another step that isn't necessary. so I simply drain the lines, then flush/fill with pink RV antifreeze. I use about 2 gallons, this includes dumping some into the ptraps and toilet.
I open low point drains and all the faucets, then come back in a few days and pump pink into all the lines. The whole process takes about 15 minutes and I don't need to drag the compressor out.
If you decide to blow the lines out, use one the of brass fittings attached to the city water. Your compressor should have a regulator, set it to about 20-30 psi.
Hook the air line up to the fitting, then start with the farthest faucet, open one faucet at a time, until it starts puffing air. Don't forget the toilet, outside faucets, and the washing machine. When finished, let it sit for a few minutes, then repeat the process.
I would drain my water heater by removing the drain plug, and close the bypass valves.
2001 Coachmen Mirada (Ford F53 6.8L V10) - Toad 2003 Saturn Vue
It won't do MACH 2, but I can get a sandwich and take a pee.
waiter21 is offline   Reply With Quote
Old 10-01-2016, 05:30 AM   #8
Usually Confused Member
emm-dee's Avatar
I'll add that when you remove the anode rod from the water heater be sure there is no compressed air in the system. You might get a little wet. Don't ask me how I know that.
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Vengeance 25V (the Harley needed a home)
emm-dee is online now   Reply With Quote
Old 10-01-2016, 07:10 AM   #9
rp53's Avatar
thanks for the advice folks, that's what i like about this place if u have a question there are plenty of folks willing to help out
Old 10-01-2016, 07:14 AM   #10
I just find an old garden hose end and clamp it on to my air compressor hose fitting.
2012 Windjammer 3001W
2016 Sunset Trail Super Lite 250RB-For Sale
2015.5 Chevrolet Silverado 2500HD LTZ crew cab Z71 4x4
KingFisher is offline   Reply With Quote
winter, winterize
