Old 09-21-2012, 12:51 PM   #11
Herk7769's Avatar
Originally Posted by billclay2004lex View Post
OK I found the ground wire and put all three red wires and one with a fuse in it to the plus terminal of the battery! The 12 volt system works now but the fan on the converter box now runs all the time!
Your batteries are most likely VERY low and the converter is working overtime trying to charge them.
HAM CALLSIGN - KC3FFW
Old 09-21-2012, 01:29 PM   #12
Triguy's Avatar
That sounds about right. They could be very low depending on how long they sat on the shelf.
Just so you know, it might take very long for these batteries to get to a full state of charge (depending on how big they are).
If you wish, you can continue to try and charge through the converter/charger or use a good three-stage portable charger connected directly to the batteries.
I have two 6-volts that I prefer to charge this way rather than through the converter.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 09-21-2012, 03:26 PM   #13
Hob
With all of the college education in electronics on here, they have neglected to tell you the most important thing. "Don't lick bare wires."
Hob is offline   Reply With Quote
Old 09-21-2012, 03:26 PM   #14
Thank You!
bill2004lex is offline   Reply With Quote
Old 09-21-2012, 04:06 PM   #15
Start engine and charge with alternator.
dunk05 is offline   Reply With Quote
Old 09-21-2012, 04:06 PM   #16
works pretty quick or just drive around a little
Old 09-21-2012, 04:08 PM   #17
Haven,t done that in a long time. Have been an electrician since 1955. I only grab 440 volts with bare hands. Only once
Old 09-21-2012, 04:14 PM   #18
Herk7769's Avatar
While you might think this works, you will never get more than 5 or 10% capacity replacement doing this. The voltage will mostly recover quickly but the capacity takes a lot of time.
Ignoring the tapering off of charging current as the voltage comes up (the alternator is a single stage charger) and say "on average" the alternator charges at an average 7 amps (if does NOT as on average it is MUCH less); it will take OVER 10 HOURS of "driving around" to charge up a 75 amp hour coach battery.
The physics is complicated but here are some charts to provide the visuals.
Name:	battery voltage and capacity Curve.jpg
ID:	19764   Click image for larger version
Name:	Charge Chart.jpg
File Type: pdf Automobile Alternators as Chargers.pdf (805.9 KB, 12 views)
Old 09-21-2012, 04:54 PM   #19
I am now plugged in to 115 volts...should charge batteries by tomorrow?
Old 09-21-2012, 06:44 PM   #20
Herk7769's Avatar
It has been my experience (using the capacity meter built into my TM-2025-RV battery monitor system) that over night on the converter will bring your battery up to about 90% capacity. It will take about 3 days on the converter (total) to bring it up to 100%.
This is due to the "Float Mode" of the converter reducing the charging amperage to less than 1 amp for the "top off" - Trickle Charge stage.
