Old 09-04-2016, 08:41 AM   #11
I have a similar issue. One day 12V system working great, next day nothing works on 12V, but works fine when plugged in. I did not do anything between those 2 days except unplug/replug the 120V.
Checked the battery and it's showing 11.5V. So it's not been charging. Checked all the fuses inside and underneath and next to the battery and under the tongue and all are good.
I need help on what I'm seeing underneath the tongue. First picture is overview. Second picture is a terminal block or ??? that I'm asking about. It has 11.5V showing across the 2 connections. I would expect 0V if it's just a terminal block, so I'm wondering if it's a fuse or something that's blown. Seems like this is the path to getting power to the big metal box where all the connections are.
Any ideas?
ID:	119351   Click image for larger version
2012 Flagstaff 26 Super Light
2003 Toyota Tundra
rcrodriguez is offline   Reply With Quote
Old 09-04-2016, 12:09 PM   #12
f5moab's Avatar
Looks homemade to me. The box looks like the standard electrical junction block used in homes.
f5moab is offline   Reply With Quote
Old 09-04-2016, 12:21 PM   #13
clr
The item you are calling a terminal block is a circuit breaker. There should be a very small button on the side of the terminal block push this button that should reset your breaker.
Chuck & Sandra
Engineer/Teacher
2010 F350 CC 6.4
2015 Prime Time Sanibel 3601
clr is offline   Reply With Quote
Old 09-04-2016, 08:13 PM   #14
CLR, you are right. That's exactly what it was. Battery is charging again.
Thank you very much!
2003 Toyota Tundra
Old 09-04-2016, 11:21 PM   #15
Moderators' Assistant
bikendan's Avatar
Just for info, the most common cause of tripping this breaker, is crossing the battery wires.
Usually happens when installing the battery.
Dan-Retired Firefighter/EMT
2016 PrimeTime TracerAIR 255, pushing an '07 Chevy Avalanche
Equalizer WDH and Prodigy BC
Old 09-05-2016, 08:15 AM   #16
My cause was something else. I haven't touched the battery since I've had the RV. (Only 6 weeks.). If it trips again I'll investigate what else may be causing it.
2003 Toyota Tundra
Old 09-05-2016, 09:19 AM   #17
If you haven't touched the battery in 6 weeks, and the camper isn't plugged in, the battery is dead. The circuit breaker (or the battery fuse or reverse polarity fuse in the converter) often pops when a WFCO converter attempts to recharge a dead battery.
When in storage, there are parasitic battery draws that run your battery down. With a good battery, this will normally take about 2 weeks. The propane/CO/low voltage alarm is the biggest culprit. In my A-frame, the stereo likes to turn itself on, too. The low voltage alarm may/may not chirp loud enough for you to hear it outside the popped down camper.
Bottom line is that you need to disconnect the battery when not using the camper (and it's not plugged in). I eventually installed a battery disconnect switch because I'm lazy, but got tired of replacing dead batteries.
Fred W
2014 Rockwood A122 A-frame
previous 2000 Coleman Westlake pop-up
Old 09-05-2016, 09:49 AM   #18
Head Rambler
I don't normally disagree with Dan , but I'd think the most common cause for tripping the 'ShortStop' (circuit breaker) is plugging in shore power and the converter trying to charge a dead or severely depleted battery.
From the looks of the terminals in the second pic, I'd be reterminating all those connections. Looks like there's some pretty good corrosion, especially on the junction box side. Wouldn't hurt to cover them with dielectric grease once you've reterminated them.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Old 09-05-2016, 04:39 PM   #19
When I said I hadn't touched the battery, I meant I'd never connected/disconnected it. I've been regularly using or maintaining the RV, and plug it in at least each weekend.
Agree the connections need some work. It's been added to the list!
2003 Toyota Tundra
Old 09-06-2016, 12:40 PM   #20
Head Rambler
Sometimes if the battery is a little low and you use a large draw device (i.e. slide or landing gear) it will blow the 'ShortStop' because the low voltage will cause a higher than normal current draw.
Gotta go campin!
12 volt
