Follow up to my battery drain. Issue. Turns out there were 2 items causing this problem. First there was a blown fuse under the hood of TV that connects to hitch plug. Secondly I believe my setting the fridge on dc for travel as you fellow members pointed out is the real culprit. So for my next outing I will run it on has, and with the new fuse I should be all set. Thanks for the advice.
