Old 07-06-2016, 11:12 AM   #11
wmtire's Avatar
Originally Posted by bigpete48 View Post
The circuit breaker is a "short stop 12v w12 40a" in line circuit breaker. If I blew it, is there anything that I need to replace in order to reset it, if not, how do I reset it?
Thanks again for the support, this is proving to be a great resource.
There should be a little black button on the end/side of it, that you push in to reset. It shows up in the link I provided in post #4.
Edit: See the little black button on the end in the pic below? Push it in on your resettable fuse/cb
2011 Flagstaff 831 RLBSS
Materialism: buying things we donít need with money we donít have to impress people that donít matter.
Old 07-06-2016, 12:10 PM   #12
Moderators' Assistant
bikendan's Avatar
Originally Posted by ilmor View Post
Are you sure that your main battery disconnect switch is turned on (if it has one)?
Popups don't have factory disconnect switches.
A previous owner would have to installed one.
The OP has to find the resettable breaker and press the black reset button.
Dan-Retired Firefighter/EMT
2016 PrimeTime TracerAIR 255, pushing an '07 Chevy Avalanche
Equalizer WDH and Prodigy BC
Old 07-06-2016, 12:52 PM   #13
MissouriCamper's Avatar
If it is none of the above, I would look for corrosion on the battery cables, had something like what you had a couple of years ago on my travel trailer and it was just a matter of a little wire brushing.
Mike & Shirley
Millwright (Retired)/Homemaker
2002 F150 Lariat super cab
5.4L 3:55 prodigy
2006 Rockwood 2603
MissouriCamper is offline   Reply With Quote
Old 07-06-2016, 01:13 PM   #14
My circuit breaker doesn't have a button to reset it, it seems to be one of the automatic reset models. Is anyone aware of how long does that takes to reset?
bigpete48 is offline   Reply With Quote
Old 07-06-2016, 02:43 PM   #15
Head Rambler
Some of them don't have the reset button. I've had to replace a few that wouldn't reset on their on. Most auto parts stores have them in stock.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Old 07-10-2016, 01:41 PM   #16
More help
OK, so I checked the fuses, they are all good. I plugged into shore power, the lights, fan etc, still don't work! T
his is really starting to make me angry, the thing is less than one year old. Also, when I plugged into shore power, the fuses go hot to the touch, any suggestions. What are the odds that the power inverter is bad?
Old 07-10-2016, 01:52 PM   #17
wmtire's Avatar
I think you mean to say converter, not inverter.
You need to read post #9 again about blowing the converters reverse polarity fuses when/if you connected the battery backwards (which I think you stated you did).
These have to be replaced before the converter (which powers all your 12 volt items when connected to shore power) can function. This fuse(s) may be in electrical distribution panel, or could possible be on the converter itself.
Were you able to specifically locate the reverse polarity fuse(s) in your distribution panel?
Old 07-10-2016, 01:56 PM   #18
I found the fuse. I took it out and it appeared to be fine. It looks like it is a fine fuse. I will test it, but I think it is ok.
I just tested all the fuses. They are good.
When I connect to shore power, the AC outlets work, but nothing else seems to work. I am not an electrical expert to begin with and I am really getting frustrated. Any suggestions please?
The only thing that I have not tested is the circuit breaker. I found it, but there is no reset button. There seems to be an inline one right at the batter and then one on the trailer tongue as were posted earlier. Should I take the inline one at the battery out and see what happens.
Old 07-10-2016, 02:12 PM   #19
Flybob's Avatar
If you have a meter, measure the voltage across the fuse and /or breaker . It should be zero ( or very close). If there is a voltage across the fuse / breaker, it is open .
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
Old 07-10-2016, 06:47 PM   #20
...So if the voltage is 0, the breaker is closed? Which means it is good or bad?
power
