Old 07-10-2016, 06:55 PM   #21
HONDAMAN174's Avatar
12v wont power anything!?!
The breaker at the battery is usually for the lift motor. If they don't have a button, then they reset once power is removed.
And follow your positive cable underneath your unit. There is usually another circuit breaker at the front where the 7 pin connector connects to the trailer wiring
2014 Evo 2850 "Woodstock"
2011 Toyota Tundra "Clifford"
Just glad to get away
Old 07-10-2016, 07:18 PM   #22
How do I tell if the breakers are bad?
I have checked all the fuses, charged the battery, cleaned the terminals and still nothing. When I hook into shore power all of the AC plugs in the camper work, but that is it. No lights, no lifter winch, no roof fan, etc. I am at a loss. We are going camping next week, and I would really like my brand new camper to work correctly. I am feeling really defeated!
Thanks everyone for all of your suggestions and support.
bigpete48 is offline   Reply With Quote
Old 07-10-2016, 07:32 PM   #23
Flybob's Avatar
Set voltmeter to 20VDC. Put one probe on the + side of the battery. put the other probe on a clean contact point on the frame. What is the reading?
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
Old 07-10-2016, 07:39 PM   #24
-12.73
Old 07-10-2016, 07:45 PM   #25
Flybob's Avatar
Was the Red probe on the Plus terminal of the battery?
TST Tire Monitors
2 65W solar panels
Old 07-10-2016, 07:49 PM   #26
Definitely on the positive terminal, think it was the red one.
Old 07-10-2016, 07:49 PM   #27
I am not an electrically inclined guy :-)
Old 07-10-2016, 07:52 PM   #28
Flybob's Avatar
Something is strange. You should not see a negative voltage. Are you sure the battery is connected correctly?
TST Tire Monitors
2 65W solar panels
Old 07-10-2016, 08:03 PM   #29
positive to the black wire, negative to the white wire. I don't know what the heck is going on.
I followed the white wire back, and it is connected directly to the frame, as was suggested in an earlier post.
The other odd thing was that the fuses all seemed to get very warm to the touch when I plugged into shore power. I thought that was unusual. I really have not the foggiest, luckily I am learning a lot with this adventure and everyone on this forum has been great so far.
Old 07-10-2016, 08:50 PM   #30
Scubanut's Avatar
I just bought this book from Amazon last week and working my way through it. All explained in easy to follow and understand. Might not help you now but to understand how all your systems work "priceless"Click image for larger version
Name:	ImageUploadedByForest River Forums1468202095.775609.jpg
2012 F150 FX4 Crew 5.0 3.73 gears
2O12 Coachman Freedom Express 292BHDS (outdoor Kitchen)
Scubanut is offline   Reply With Quote
power
