Old 07-06-2016, 09:06 AM   #1
12v wont power anything!?!
Hi, I was hoping for some help. I have a 2015 Flagstaff MAC 228BH that I used a few times last year with no issues. This year, after taking it out of storage, I tried to put the battery back in it (yes it is good and yes, it is fully charged) and I am getting nothing! The electric lift system is not even working. No lights, no nothing. I can't hook up to shore power because the connector is in the camper.
I know that there may be a fuse issue, but my immediate concern is to get the lift working, so I can get in the camper and check everything else out. Any suggestions as to what could be wrong with the winch system. Thanks for anyone's input, I really appreciate it!
Pete
bigpete48 is offline   Reply With Quote
Old 07-06-2016, 09:10 AM   #2
ilmor's Avatar
Pete
Are you sure that your main battery disconnect switch is turned on (if it has one)?
2017 Forest River Sunseeker 2250SLE
ilmor is offline   Reply With Quote
Old 07-06-2016, 09:11 AM   #3
Mr. Dan's Avatar
I'm not saying this is the problem....... but there are many posts on here about people hooking up their battery backwards. The wire colors are not what some people expect so it's relatively easy to do. If hooked up backwards, two large (30-40amp) fuses in the fuse panel are blown and nothing 12v works. Make sure your negative (-) cable goes to ground/frame... then check these two "reversal" protection fuses.
SEARCH is your friend!
Nights Camped: 2013 = 49 / 2014 = 74 / 2015 = 74 / 2016 = 85 / 2017 = 14; booked = 28
Old 07-06-2016, 09:12 AM   #4
wmtire's Avatar
#1 thing is to make sure you connected the battery leads correct. Many times an RV is wired color code wise like a house. If you have a white and black cables, the black is to the positive and the white is to the negative.
If you wired it backwards even for a second, you blow the reverse polarity fuses to the converter, but this won't show up until you connect to shore power.
You also have a resettable fuse on your trailer frame, that this thread may help in locating and resetting. I would check it too, as it's an easy problem/fix
Battery power gone
2011 Flagstaff 831 RLBSS
I've invented a new word. "Plagiarism"
Old 07-06-2016, 09:12 AM   #5
Pete
Do you have a battery disconnect switch? I mean no offense by this, is the battery hooked up correctly and what have you done to verify the battery is good?
If indeed the bat is good and you have no disconnect switch (or the disconnect switch is in the correct position) then I would start checking fuses breakers.
2015 Forest River EVO 2850
2012 Dodge Ram 2500 6.7 Cummins
Yamaha 2k x 2 with parallel cable
EMS 30 PI portable w/ Edison plug
Nights Camped (2016-13) (2015-13)
SuicideSaints is offline   Reply With Quote
Old 07-06-2016, 09:13 AM   #6
Flybob's Avatar
Check the two large current fuses in the fuse panel 30-40A then check the resettable breaker on the tongue ( Usually red rubber cover). If you had any issues while putting the battery back in these would trip. Breaker looks like this only cover probably red.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
Old 07-06-2016, 10:30 AM   #7
I think that I did put the battery in wrong. The white and black wires screwed me up, I guess. I am used to black being negative. I thought that that might be the problem based on other threads. I know the battery is good, I charged it AND had it tested yesterday at Parts America.
Would this still cause the crank not to work, I thought that was wired independently?
Old 07-06-2016, 10:35 AM   #8
Mr. Dan's Avatar
Check the resettable breaker Bob mentioned in post #6.
Old 07-06-2016, 11:05 AM   #9
wmtire's Avatar
Since you are not connected to shore power, then ALL 12 volt DC items will need power from your battery. If the resettable fuse/CB is tripped on your frame rail, then the lift cannot get power from the battery. I provided a link in post #4 that has pics of this resettable fuse, and the little black button you need to push in to reset it.
Normally, even with your battery wired backwards, your 12 volt stuff would still work, just all the switches would function backwards. What normally is up, would now be down.
Once you do make sure the resettable fuse on the frame rail is not tripped (or you reset it), then once you get inside your popup to connect to shore power, your are going to need to also replace the most likely blown reverse polarity fuses to your converter. (these cannot be reset but have to be replaced).
This link will help you in that endeavor:
Electrical problem
Old 07-06-2016, 11:10 AM   #10
The circuit breaker is a "short stop 12v w12 40a" in line circuit breaker. If I blew it, is there anything that I need to replace in order to reset it, if not, how do I reset it?
Thanks again for the support, this is proving to be a great resource.
power
