Old 09-14-2014, 12:54 PM   #1
wstensgaard's Avatar
'14 HW296 Powerwinch
Just got back from our second voyage and while we were taking down a friend of ours mentioned how loud our winch was. When we listened to their winch on a RW Freedom it was silent. Anybody have and input on this? HW296 owners notice this as well or do we have a problem? Thanks in advance for input.
wstensgaard is offline   Reply With Quote
Old 09-14-2014, 02:18 PM   #2
check the bolts on the motor. Ours came losse and one fell out, causing the gears to chatter and disengage, before I found the problem. The winch is still loud, but at least it's working. If you want quiet, use the power drill with deep 3/4" socket to turn it.
mtaylor42 is offline   Reply With Quote
Old 09-14-2014, 02:18 PM   #3
HONDAMAN174's Avatar
You need to put grease on the worm gear every so often. Take off the winch cover and cram a glob of multi purpose grease in and around the worm gear. I would do it about every 5 trips but I was also in a really hot climate.
Use a grease gun to fill the cable tubes underneath. I also liked using "chain lube" on the cable- I thought I made a difference.
2014 Stealth Evo 2850 "Woodstock"
2011 Toyota Tundra Rock Crawler TRD 5.7 "Clifford"
Just glad to get away
Old 09-14-2014, 11:22 PM   #4
If it's a new unit (2014), they are loud. We have a 2014 2514g, and the winch is loud as well. They changed to a new style, and the dealer warned me about it at the Delivery. Might be worth a few mins just to check it out, but coming from another owner, they are just plain loud.
cousin_eddie is offline   Reply With Quote
Old 09-15-2014, 06:30 AM   #5
vinmaker's Avatar
Load is scary. I do not like loud. I always think loud means it is breaking. lol.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 09-15-2014, 07:25 AM   #6
My 2015 HW 276 is scary loud compared to others I've owned, but "they " say it's normal,I hope " they" are right
GB guy is offline   Reply With Quote
Old 09-15-2014, 12:56 PM   #7
GypseeDaddy's Avatar
I have a 2010 HW276 and the winch is loud. This is the first one I have had with a winch, so I asked the dealer and he said that it was typical for this unit....for what that's worth. I've had mine up and down at least 20 times in the past 12 months with no issue to date.
GypseeDaddy
2010 Rockwood HW276
2014 Honda Ridgeline 4wd
GypseeDaddy
2014 F-150 XLT Supercrew 4x4, Timbrens
2015 Zinger 28BH
GypseeDaddy is offline   Reply With Quote
Old 09-15-2014, 01:32 PM   #8
And I thought my 2012 was loud-can't imagine if they got louder!
Old 06-14-2015, 08:09 AM   #9
I just bought a 2015 2317G and my powerwinch is scary loud as well. I can't believe that any design this loud would be sold on purpose. Mine sounds like an impact wrench at a tire store. I intend to take it apart and see if I figure out where that noise is coming from. I need to open it up to adjust the limit switches since the dealer/mfg apparently didn't do it for me.
ckokosa is offline   Reply With Quote
Old 06-14-2015, 09:10 AM   #10
Vin, my thinking is quite is bad. Lol. These winches are load which can stink if ur setting up at night. They say don't grease the new style winch
kinma13 is offline   Reply With Quote
power
