Old 07-26-2014, 08:40 PM   #1
1984 rockwood roof won't stay up
The roof system is the spring lift system. After cranking it all the way up it falls down. There is no clicking noise while cranking up or down . Can someone please let me know what's going here?
dhartwell is offline   Reply With Quote
Old 07-27-2014, 08:34 AM   #2
I would check the rachet to see if the spring is on rachet lever.( in green on illustration) if you are getting the clicking sound but the camper roof is going down then i would check the friction plate and tension on it or to see that no oil has gone on it.
Name:	manual crank.jpg
bleurt is offline   Reply With Quote
Old 07-29-2014, 11:49 AM   #3
I'm not getting any ratcheting sound. Also my ratchet system is different than your diagram .
Old 07-29-2014, 07:56 PM   #4
is it a worm gear off the motor. if so the. it is old model. they have changed to new model with rachet. There was a recall for models shipped in 2007
http://www.carefreeofcolorado.com/do...nch_Recall.pdf
Old 07-29-2014, 08:02 PM   #5
If i was you iwould go to dealer and order the new system it is like 400$ mine broke at the campsite and i had to spend my first nigth at a hotel umtil i could get a pulley and cable u bolts and come a long to lift the roof so i could camp.
rockwood, rockwood roo, roo, roof
