I have a 2016 206LTD MAC with 12" tires and the sticker for the torque setting on the lug nuts is not readable. How many ft-lbs should I torgue the nuts to?
Just as the name implies you tighten and torque in 2 stages. The first stage is to be sure that the wheel is properly seated on the hub. The second is to take the lug nuts up to the final torque. Just a way to keep you from cranking down the lug nuts too soon and warping the wheel, or in some cases, the brake rotor.
