Old 09-20-2016, 12:44 PM   #1
228bh sink drain flex hose replacement
came back from a 4-day trip in mountains and noticed some water left on the floor. after checking around, found out the flex hose for sink drain line was broken. cut the broken part and the hose was not long enough so I have to buy a new one, but it seems not easy job to find one. the hose has a non-common size of 1-3/8", the local store normally has 1-1/4" or 1-1/2", googled online, saw one on Amazon for water fill hose, not sure if I can use it.
the one on amazon.ca:
https://www.amazon.ca/gp/product/B00...f_rd_i=desktop
just wondering if someone happens seeing this 1-3/8" flex hose before. attached is the flex hose (white one).
thanks.
Name:	2016-09-12 18.34.29.jpg
Andy
2014 Toyota Sienna
2014 Flagstaff 228BH
air lift 1000
ayangch is offline   Reply With Quote
Old 09-21-2016, 08:26 AM   #2
Check here and see if this is may help you. They have the 1 3/8 that you are looking for
Flex Fill Hose
JPBar is offline   Reply With Quote
Old 09-21-2016, 08:35 AM   #3
Butch Wilson's Avatar
I bought one at a camper dealership parts department. It seems to be fairly unique to campers.
Butch Wilson
2016'Flagstaff T21QBHW A-Frame
Butch Wilson is offline   Reply With Quote
Old 09-21-2016, 09:48 AM   #4
Flex Fill Hose
thanks, it looks same as the one at amazon. I will buy one from amazon then.
Andy
2014 Toyota Sienna
air lift 1000
Old 10-19-2016, 12:25 AM   #5
Sink Drain Line Failure and Replacement
I also had a pinhole leak develop in the sink drain line on my tent trailer. I purchased a replacement hose (1 3/8") from a local RV dealership for about $3 for a 4' hose. It was identical to the original that failed on the tent trailer.
joefram is offline   Reply With Quote
28bh, drain, replacement, sink
