Old 05-26-2014, 05:35 PM   #1
2302 premier water heater pilot won't light.
All other propane appliances work. Any tricks to get it to work?
Coach Kemble is offline   Reply With Quote
Old 05-26-2014, 09:55 PM   #2
BigMac
bmcilravey's Avatar
I don't profess to be an expert or near knowledgeable on this topic but I had a similar thing happen to me last year. I was advised that sometimes your system can overpressure by opening the valve to fast.
so here are the steps that worked for me:
1. Turn off gas at tank
2. Open an appliance to let remaining gas out (do so with caution obviously)
3. Close appliances
4. Open main gas again, but do so very slowly so you do t over pressure.
Try relighting.
Hopefully that works. If not, someone with some gas knowledge may have something better for you.
bmcilravey is offline   Reply With Quote
heater, light, water, water heater
