Old 06-02-2015, 04:44 PM   #11
HONDAMAN174's Avatar
Originally Posted by Dilbert View Post
Positive I didn't reverse the battery cables, have had old battery in and out several times.
Did not find a resetable circuit breaker. Did however see the connections pictured attached directly to the battery, but no reset button on the thing. What is that anyway?
I believe that is a power winch circuit breaker to raise the roof. Most resetable circuit breakers are underneath the frame. Follow your wires back to the convertor.
Just glad to get away
Old 06-02-2015, 05:08 PM   #12
Flybob's Avatar
Check the two large 40A fuses in your convertor. They could be blown. Usually yellow .
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 06-02-2015, 06:39 PM   #13
Found the problem, now working!! Thanks for the help!!!
Dilbert is offline   Reply With Quote
Old 06-02-2015, 06:42 PM   #14
bikendan's Avatar
What was the problem? remember, you'll help others by informing us.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 06-02-2015, 07:28 PM   #15
It was the 30 amp fuse in the positive line. Replaced once but must have blown when I changed the battery.
Old 06-16-2015, 03:51 PM   #16
TURBS's Avatar
Resetable circuit breaker under the a frame? Have checked that?
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "9 nights"
Old 06-16-2015, 03:55 PM   #17
Reuben
Dilbert, I'm following your post as well. I have the same problem. With shore power - everything works. Unplug and nothing. I have a new battery (tested good), checked all inside fuses, checked the in-line fuse coming off the battery, and all relay posts on top of the battery show 12 volts. Just bought the pup used (2 year old HW276 popup) - it had the problem when I bought it and I assumed it was the battery. I see you fixed your problem by replacing the in line fuse - guess my problem is a little deeper.
Reuben Sandwich
Reuben Sandwich is offline   Reply With Quote
Old 06-17-2015, 12:03 PM   #18
Did you test the in-line fuse or just do a visual? I thought mine was good by looking at it. Didn't see any breaks thru the side view, but replaced it anyway and it fixed the problem.
Old 06-17-2015, 01:47 PM   #19
Reuben
Dilbert - thanks.... that was it.
My first visual test on the fuses missed a hairline crack - second test I used a continuity tester & found the bad fuse. Replaced it & all is up and running as it should. Thanks again. (Now I need to figure out this 1-1/2" outlet on the grey tank..... certainly won't work with my sewer hose!)
Reuben Sandwich
2514g, fan, light, power, radio, pop up
