Old 08-28-2014, 03:40 PM   #1
3 way Fridge question
I have a 2015 Rockwood HW276. I parked and set it up to unload from last trip and getting ready for this weekend. PUP is still set up but I want to turn the fridge on and load it in the morning. The PUP is level front to back but it is not level side to side. I have a BAL leveler or an Anderson but cant use either without putting the PUP down and moving it to cement. question is can i turn the fridge on and run it even if its not level front to back? fridge is located along the side on the PUP.
kinma13 is offline   Reply With Quote
Old 08-28-2014, 04:36 PM   #2
msantos's Avatar
I would level it first
msantos is offline   Reply With Quote
Old 08-28-2014, 04:56 PM   #3
Thats what im thinking. Ive read that the fridge can be off about 6 degrees but not taking the chance.
Old 08-28-2014, 06:16 PM   #4
vinmaker's Avatar
Better off leveling as best you can. I try to park my unit in a place that I can make it level for that reason. So i throw a board under the wheel if I have to make the side to side level.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 08-28-2014, 08:03 PM   #5
Yeah moved it to the cement. Didnt want to take a chance.
Old 08-28-2014, 08:16 PM   #6
VinceU's Avatar
Just for the future, Dometic suggests level as possible however if the floor is "comfortable" to stand on it is ok to operate the fridge.
Old 08-28-2014, 08:20 PM   #7
I don't believe you can hurt it, it just may not get cold. Give it a try.
2011 Traverse LT, 3.6L, FWD
Old 08-28-2014, 09:44 PM   #8
Pill Billy's Avatar
For side install fridges, front to back leveling is all that matters so the ammonia is allowed to trickle back down and recirculate.
Pill Billy is offline   Reply With Quote
Old 08-28-2014, 10:05 PM   #9
Thanks everyone for the answers. I moved to trailer so I could level it. Floor did feel lean to 1 side.
Old 08-29-2014, 06:40 AM   #10
vinmaker's Avatar
That is good to know. Front to back is most important. That is good as that is the easiest to do.
Vin.
2015 HW296
2013 Chevy Tahoe
Equalizer WDH 1000#
fridge
