Originally Posted by Oaklevel
When you 1st turn the gas on do you run the stove top first (assuming that you have one), to get any air out of the lines??
That's the way I do it. When traveling, I turned the gas off at the tank. Fridge runs on DC while on the road (won't stay lit on propane). If there is no electric at the campsite, I immediately turn the fridge off while I set up to save battery. When setup, I light the stove for a minute or two to get any air out of the lines.
After lighting the stove, I then go to light the fridge. The "2 push" of the ignitor button is also recommended by Roberts RV here in Denver - they rent out pop-ups and only sell A-frames and pop-ups.
My techniques will change now that I have a high wall with a fridge with auto-ignition (and takes 175 watts on DC instead of 120). I expect to use propane on the road.
Fred W
2014 Rockwood A122 A-frame
2019 Flagstaff T21TBHW A-frame
2009 Hyundai Entourage minivan
