Old 07-23-2015, 08:51 AM   #11
That would be awesome Gator ... Thanks!
2013 Forest River Rockwood Highwall 296
1991 Chevrolet Suburban V2500
gpwooden is offline   Reply With Quote
Old 07-23-2015, 11:06 AM   #12
2gwright's Avatar
Here are all the pictures I have.
first picture is all the way up before I made new poles.
second picture is with new poles showing tie down method.
third picture is close-up of straps with single ratchet strap laced through all bikes.
Note that on the far side of picture two I have a Toy-Lock attached to the top tube of the rack so that I can lock all the bikes together.
Name:	HW296 First picture.jpg
ID:	83872   Click image for larger version
ID:	83873   Click image for larger version
2015 HW296
2gwright is offline   Reply With Quote
Old 08-15-2015, 08:43 PM   #13
After much delay from Amazon, the ProRac finally arrived and spent this morning installing it.
There is still some good length left on the poles after using the tallest hole, so I may just drill a new sets of holes. But after a dry run with it set to the tallest hole, I think it should be just fine.
Here are two pictures of my dry run and my bike:
ID:	85822   Click image for larger version
Old 08-15-2015, 08:47 PM   #14
Thanks 2gwright for posting. I see there the additional tie-down will be required; those poles at that height tend to have some sway to them. I am going to see how these existing top setting will work out; but may end up drilling a new set of holes further down to give that additional length. Not too far however, but I believe there is some room to drill and not compromise the stability. We'll see. Thanks again for sharing!
Old 08-16-2015, 02:16 PM   #15
2gwright's Avatar
Now you have your camper and your bike. Come on over to Georgia as we have some incredible trails to ride.
2015 HW296
Old 08-16-2015, 04:00 PM   #16
GoGators904's Avatar
2gwright:
What size straps did you use?
GoGators904 is offline   Reply With Quote
Old 08-17-2015, 09:11 AM   #17
2gwright's Avatar
I think the ratchet strap is at least 16' long and I'm at the very end.
2015 HW296
Old 08-19-2015, 09:44 PM   #18
10-4. We don't get over to GA much however; we usually stick to a 3-hour radius. We may do a South GA one in October however. What part of GA are you in? I am in South Mississippi.
Old 08-20-2015, 05:08 AM   #19
2gwright's Avatar
Atlanta burbs on the north side
2015 HW296
Old 08-20-2015, 10:21 AM   #20
vinmaker's Avatar
I am not sure mine reaches that high. I wonder if they changed the design to accommodate the HW's.
I definitely need new pipes for mine.
Vin.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 1000#
bike, bike rack, forest river
