Old 05-06-2016, 07:24 AM   #1
50 Amp Electric to 20 Amp?
I am looking at a campground that only has 50 amp electricity but my popup is 20 amp. Can I use the 50 amp? Is there an adapter I need?
2004 Flagstaff 228 MAC - Retired
2015 Coachmen Clipper 17BH - Current
wheatbread is offline   Reply With Quote
Old 05-06-2016, 07:37 AM   #2
Pickin' & Campin'
A 50 to 20 adapter is sometimes hard to find but they do make them. See photo below.
You can also go 50 to 30 then to 20 with adapters that are available about everywhere.
Days Camped: '15=22 '16=46 '17=30 '18=4
Old 05-06-2016, 07:38 AM   #3
clr
Most campgrounds have all three at 50amp, 30 amp and 20 amp at the power pedestal. Most campgrounds only publicize the highest settings. Yes there are adapters (commonly called dog bones) that will adapt you from 50 to 30 and then from 30 to 20. It may be a good idea to carry them both but in most cases all campgrounds will have 20 amp service if they provide electric to the site.
Chuck & Sandra
Engineer/Teacher
2010 F350 CC 6.4
2015 Prime Time Sanibel 3601
clr is offline   Reply With Quote
Old 05-06-2016, 08:36 AM   #4
jeff64's Avatar
X2
I haven't run across a power pedestal that didn't at least have a 15/20 A. outlet. Even with the TT at 30A connected. It's not unusual to hook up an extra extension cord
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 05-06-2016, 11:37 AM   #5
Ret E-9 Anchor-clanker
donanddona's Avatar
I have used the next/closest power pole.
donanddona is offline   Reply With Quote
Old 05-06-2016, 12:14 PM   #6
NCBBA11043's Avatar
Just make sure that whatever you plug in has its own breaker or fuse (15/20A). If you had an overcurrent situation (not a short circuit) using a regular extension cord (#16 or #14), the breaker wouldn't trip until it got past 50A. The wire is only rated for 15 or 20. It now becomes a fusible link!!
NCBBA11043 is offline   Reply With Quote
Old 05-06-2016, 12:25 PM   #7
Fulltime family RVer
Originally Posted by jeff64 View Post
X2
Surprisingly, they're out there. Elkhart Campground was one that literally had just a 50amp connection and that was it. Frustratingly, I couldn't even find a breaker.
50 amp, electric
