Old 06-22-2015, 01:29 PM   #1
lickitisplit's Avatar
A/C run off drain
I tried using the pool noodle method of draining the air conditioner run off from the roof/canvas but with the foam being porous, it eventually seeped thru anyway . I searched around Home Depot and came across a two foot piece of 2 1/2" Braided Vinyl Tubing. I ran a slit down the side and tucked it under the roof. It fit snug, no sharp edges and worked great. I think the cost was between $5-$10 for the piece of tubing.
2015 Rockwood Freedom 2280
2011 Chevrolet Silverado
1979 Wife (Shannan)
2007 Boston Terrier (Darla)
2012 French Bulldog (Rocko)
lickitisplit is offline   Reply With Quote
Old 06-22-2015, 01:51 PM   #2
vinmaker's Avatar
I like it.
That is very interesting.
So the water rolls down the edge of the roof and then into the hose because you slit it?
Did you simply run a blade down the length of it?
I have used that pipe for my pool and it is quite thick. I can see it making a tight seal along the roof edge as you open the cut up to attach it. If the seal is tight, then the water may run onto the outside of the pipe?
What has your experience been?
Vin.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 06-22-2015, 02:04 PM   #3
Correct. I just used a knife and slit it down the length of the hose. This past weekend was the first time I used it and worked perfectly. One edge is tucked under the roof and the other rests on outside against the roof. I thought it would roll over it as well but the way it rests on the outside corner moulding, allows enough of a gap for water to run into the hose. I think the texture of the roof helps a little as well.
1979 Wife (Shannan)
Old 06-22-2015, 02:11 PM   #4
vinmaker's Avatar
I am going to use this idea next weekend. I have a piece in my shed I am going to fabricate tonight. Hehehe.
Thanks for the idea.
Vin.
2015 HW296
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 06-22-2015, 02:12 PM   #5
vinmaker's Avatar
One question .
What about the corner? Did you cut a perpendicular cut so it can slide up the corner?
Vin.
2015 HW296
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 06-22-2015, 02:18 PM   #6
Cool. I didn't do anything for the corner. I think that might be helping create a gap needed for the water to run into. It held up to a few rain storms and 35mph wind gusts too. I hope it works as good for you as it did me.
1979 Wife (Shannan)
Old 06-25-2015, 05:07 PM   #7
Great idea, I will try it next trip we take.. Thanks
2002 Rockwood Freedom 2318G
2004 Ford F 150 5.4 liter
3 Chihuahuas Sammy, Delilah,Gypsy
nineoaks2004 is offline   Reply With Quote
Old 06-27-2015, 07:07 AM   #8
run off
Good fix. I will try the same. I bought some Cabelas space blankets to cover the bunk ends on my rockwood 1940 pup and they fit great (one side completely, the larger bunk about 5/6) and help keep debris, tree sap, etc., off the roof canvas. Keeping that AC constant drip off should also help extend the life of the canvas.
2012 Rockwood 1940ltd
2004 GMC Sierra 4x4
Ringbill is offline   Reply With Quote
drain
