Old 07-04-2015, 09:46 PM   #11
Crockett's Avatar
Originally Posted by Ken K. View Post
I have a 2015 2502KS. I run all 3 on occasion on a 30 amp service.. I don't notice anything funny. Everything seems to work just fine. I have a 15,000 btu AC. The fridge is your standard nonresidential RV fridge runs on gas and electricity. Even still the lights don't even dim. the water is very hot!
id be checking the voltage regularly...if you get below 110, id drop the WH. it will shorten your life span on appliances and melt down connections eventually
Crockett is offline   Reply With Quote
Old 07-04-2015, 09:49 PM   #12
flagst228's Avatar
Ac..fridge...water heater
The water heater runs on propane,but has a switch on the inside of the camper you have to turn on to ignite it. I do watch the voltage at the surge protector
flagst228 is offline   Reply With Quote
Old 07-05-2015, 08:23 AM   #13
f5moab's Avatar
Run the fridge on propane, in my experience it works best on propane anyway. Water pump does not pull much.
f5moab is offline   Reply With Quote
fridge, heater, water, water heater
