Old 07-06-2016, 10:25 AM   #1
AC Question
Have a 2015 hw276, camping this week and the outside temp was about 90+. Had the AC on max bit the pup really never had a problem. We cleaned the filters but no luck. Thinking it was the power pole from cg. + just being at those temps. Does anyone know besides adding gizmos what I could do?
kinma13 is offline   Reply With Quote
Old 07-06-2016, 10:59 AM   #2
Head Rambler
I assume you mean that the RV never cooled down. Of course the temps being 90+F outside had a lot to do with it as would your location and if there was any shade.
Did the air coming out of the returns seem to be cool like it should be? If so, then adding Gizmos is probably your best bet.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Old 07-06-2016, 12:14 PM   #3
Moderators' Assistant
bikendan's Avatar
Gizmos and Reflectix for the windows are about it for solutions.
Dan-Retired Firefighter/EMT
'07 Roo 23SS pushing an '07 Chevy Avalanche
Equalizer WDH and Prodigy BC
Old 07-06-2016, 03:13 PM   #4
Air at the unit was kinda cold. Seems like it was colder last year but prolly not.
Old 07-06-2016, 03:35 PM   #5
Head Rambler
You can check it with a thermometer. The return air should be about 15F colder than the intake air after it's been running a while. While you're there, you should also check for any air leaks between the intake and return. That will greatly affect the cooling ability of the unit.
Gotta go campin!
Old 07-06-2016, 04:09 PM   #6
MiCamper6's Avatar
Make sure the unit didn't freeze up also.
MiCamper6 is offline   Reply With Quote
Old 07-06-2016, 05:32 PM   #7
Reflectix in the bunk ends makes a big difference. I have pugs, but I have not yet used them. Shade or just some shade makes a huge difference in itself.
spurticus is offline   Reply With Quote
Old 07-09-2016, 05:10 PM   #8
Gizmos and Reflectix cooled mine tremendously. I read a lot spent the money and tried it. Amazing the difference it made for my 1 year old taking naps during the day.
lakecumberland is offline   Reply With Quote
Old 07-11-2016, 11:49 AM   #9
vinmaker's Avatar
Kimna. I have a low profile a/c unit on mine and it tends to freeze up and will not blow much air. I have yet to use it in direct sunlight which might help thaw it out as it works. All my use tends to be under trees with shade. I will have to lower the thermostat to have it cycle on and off more so that it has a chance to thaw. Very frustrating as my older more common unit worked very well and never had a problem.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 07-11-2016, 12:04 PM   #10
TURBS's Avatar
Restricted air " intake or exhaust" flow will cause freeze up.
Frost sensor may have fallen off or is faulty.
Have you tried to open the quick cool dump feature?
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
2016 nights camped "14"
