Old 07-20-2019, 05:54 PM   #1
JasonRW1910ESP's Avatar
AC quit working
Our brand new rockwood 1910ís AC has been having trouble the last two trips. After running for a few hours, the AC stops working and barely blows any air at all at any setting. The unit is not frozen over, running on shore power. After turning it off for a few hours, it works again. Outside temp is about 88 during the day, 65 at night. What are some troubleshooting suggestions??
JasonRW1910ESP is offline   Reply With Quote
Old 07-20-2019, 06:15 PM   #2
It sounds frozen to me. What makes you think it isn't?
2011 Traverse LT, 3.6L, FWD
Old 07-20-2019, 06:18 PM   #3
Looked at the unit and not frozen on the coils .
Old 07-20-2019, 06:37 PM   #4
If the blower is turning at regular speed and air flow is greatly reduced that's usually a sign that the evaporator is iced up.
Are you sure you aren't looking at the outside "coils" which are the condenser coils where heat is exhausted from the system. Evaporator is harder to see as it's buried inside the unit.
If you have the fan set to low, try starting out with the fan on High and see if it still quits blowing air. Also, if there is an air filter in the system make sure it's clean.
Icing occurs when humidity is high and air flow is insufficient to provide enough heated air to keep the ice from forming.
My wife's old car had an automatic fan speed control. As we'd drive through humid parts of the country the air would slow from the vents, eventually feeling like it stopped. I'd manually turn the fan to max and after a few minutes it would start tossing little flakes of ice out the vents at us.
Many turn the fan to low at night because of the noise but if the humidity is high this can cause the problem. Some units have an anti-icing feature which usually just turns the compressor off for a short period to let any ice that has formed, melt. If your A/C is equipped with that feature, it could be faulty.
Check manual for troubleshooting tips (online if you can't find one that came with unit).
Sami. my Shih-Tsu "Co-Pilot" R.I.P
Politically Incorrect since 1943
"Sometimes you're the dog, sometimes you're the tree"
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 07-20-2019, 10:09 PM   #5
X2
See pic. To see the evaporator, you have to either drop the ceiling shroud inside the TT or remove the outside cover and then open up the air plenum. Depending on make, you MIGHT be able to see it if you can remove the filters, but it's still difficult.
Name:	AC with cover removed and labeled.jpg
Icing is discussed on page 3 of the attached manual:
II. Operation During Cooler Nights (Cooling
Operation).
It is important, when the outdoor temperature drops in the
evening or during the night to below 75 degrees F., that the
thermostat (temperature control) be set at a midpoint between
“Warmer” and “Cooler”. If the setting is at “Cooler”, the
evaporator coil may become iced-up and stop cooling. During
the day when the temperatures have risen above 75 degrees F.,
reset the thermostat switch to the desired setting.
NOTE
Should icing-up occur, it is necessary to let the cooling
(evaporator) coil defrost before normal cooling operation is
resumed. During this time, operate the unit in the “HIGH
FAN” position with the system at maximum air flow. When
increased or full air flow is observed, the cooling coil should
be clear of ice.
Also, some AC units have an icing sensor that's supposed to shut off the compressor if ice is detected; some forum members who have had icing problems have subsequently reported that the sensor had shifted or fallen off the evaporator.
File Type: pdf Coleman-Mach operation and maintenance instructions.pdf (646.8 KB, 5 views)
Old 07-20-2019, 10:39 PM   #6
Yep, my AC iced up when temps dropped to around 75 degrees. I just turned AC to high fan only for about 30 minutes, then back to the high fan cooling. Problem fixed and back to normal.
2016 Ford F150 XLT, CC, 4WD, 145" WB, 5.0L, 6 speed, 3.73 9.75" Locking Axle, 1890# Payload, SAE J2807 method Actual 10,720# Tow Rating, pulling a 2020 Rockwood Premier 2716G Pop Up, with a 14' box. Previously had 2012 Jayco Jay Flight 26BH and 2008 Jayco Jay Flight 19BH Travel Trailers. Also previously had 2007 Starcraft 2406 Pop Up with 12' box and bathroom, Previously had 2005 Rockwood 2290 Pop Up with 12' box and porta potty cabinet. Trucks and Trailers.
Mike91 is offline   Reply With Quote
Old 07-21-2019, 11:30 AM   #7
Had no problem with the AC last night.
Old 07-21-2019, 05:27 PM   #8
Good, maybe just icing up then.
Old 07-21-2019, 05:55 PM   #9
Man I hope so. I donít want problems this early on a new rig.
