Old 03-29-2015, 08:50 PM   #11
Originally Posted by steamboatscott View Post
Picture of my 2-step setup: Raising Your Frame | Popup Camping 101
Thanks scott, where did you get your steps from.
2013 Rockwood popup 2318 g. TV 2003 trailblazer and a 2013 SLE Sierra p/u
campfire joe is offline   Reply With Quote
Old 03-29-2015, 11:23 PM   #12
RobertsSales.com. Perhaps they could point you to a distributor in your area. Ask for Mark - he is awesome!
steamboatscott is offline   Reply With Quote
Old 03-30-2015, 09:09 AM   #13
f5moab's Avatar
Roberts is a good place; however, you can check etrailer, camping world, and a place called RVupgrades online.
Or, if lucky, check some local shops. Just take your mounting measurements from the existing step.
f5moab is offline   Reply With Quote
Old 03-30-2015, 11:04 AM   #14
Thanks guys, i'll be ordering one in the next couple of days.
Old 04-01-2015, 05:48 PM   #15
vinmaker's Avatar
I remember the high single step into my HW256. My young children always had a hard time stepping and reaching the door handle. Visitors would also comment. My new HW unit has the two steps installed. I would recommend you do that. I am not certain, but I do think it is a simple bolt on item to the frame.
Vin.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 04-01-2015, 06:11 PM   #16
Stormrider151's Avatar
I have one of these. I got it for my Dad so he could get in and out of my truck. I now use it for my camper. Solid as a rock, has a high weight capacity and appears to be on sale.
Aluminum Folding Step - Stromberg Carlson PA-100 - Steps - Camping World
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost
Getting old ain't for wimps!!!
Stormrider151 is offline   Reply With Quote
Old 04-01-2015, 06:37 PM   #17
f5moab's Avatar
I have one of those; bought it for someone else. I never use it. Found that it tended to slip around on sand; besides the step up is not that bad.
Old 04-05-2015, 09:27 AM   #18
Dutchmen's Avatar
I think I will do the same. Easier for the older folks too
Dutchmen is offline   Reply With Quote
Old 04-05-2015, 04:06 PM   #19
flagst228's Avatar
After using our pop up the first time we were thinking about installing a double step also.They have to sell one that bolts right up since they r used on other flagstaff pop ups. That last step to the ground is higher then we thought, same as I'm no getting any younger...don't want to break a hip
flagst228 is offline   Reply With Quote
Old 04-05-2015, 08:27 PM   #20
I'll check my bolt pattern tomorrow. The front uses bolts washers, and nuts, but the back 2 are self tapping bolts. Hopefully they will be able to bolt right up, but if not i'll just drill new holes. when I call Roberts i'll give them my center to center measurements, and try and find the closest bolt pattern.
