Originally Posted by seeverest
Awesome thank you I will look into upgrading chargers.
You don't need to upgrade if your WFCO converter is working correctly. The most common problem with a WFCO converter is that it never shifts modes when it is supposed to.
According to factory specs, the WFCO is supposed to shift to trickle mode after 44 hours in normal mode with no significant change in load. Normal mode is 13.7V, trickle mode is 13.2V.
In both my Forest River A-frames, the WFCO would never go to trickle mode, even after 2 weeks in normal mode. Because of that, I replaced the WFCO 8735P converters with PD 4135 converters.
The WFCO 8735P does not have an easily replaceable converter module. Replacement means replacing the entire panel along with the converter.
The PD 4135 is pretty much a "drop-in" replacement. However, you have to move all the AC and DC circuits over to the new panel, and the circuit breakers and fuses. Depending on how much re-wiring you want to do (I didn't like the way FR did a lot of their wiring), replacing the converter is a 3-8 hour job.
I am glad I did the replacement. I don't have to worry about whether the converter is taking care of my batteries or not. Just check the battery water level every few months. And I fixed a lot of the wire nut strings while I was at it.
hope this helps
Fred W
2019 Flagstaff T21TBHW A-frame with 2 Costco Interstate GC-2 batteries
