Old 07-29-2015, 12:55 PM   #11
Originally Posted by Crockett View Post
with a popup Im assuming a 9000btu. prolly good for 50 feet with a 12ga and minimal additional loads
mine is a 13.5 Coleman mach 8
swimmarz is offline   Reply With Quote
Old 07-29-2015, 02:04 PM   #12
Crockett's Avatar
better stay 10 then...
Crockett is offline   Reply With Quote
Old 07-29-2015, 02:12 PM   #13
waiter21's Avatar
You may be at the limit - Give it a shot - Fell the plugs after the A/C has been running for an hour. If they fell hot. you probably need to re-do the plugs and connectors.
I use mine at home, but I can't run anything else when I run the A/C
2001 Coachmen Mirada (Ford F53 6.8L V10) - Toad 2001 Civic
It won't do MACH 2, but I can get a sandwich and take a pee.
waiter21 is offline   Reply With Quote
Old 07-29-2015, 04:17 PM   #14
Have run my Coleman Mach unit 13,500 BTU using 12ga 100ft 20 amp circuit. Did not get warm on the outlet or plug end after running all day. Ran TV inside as well. Unit cooled as it should but did not use micro or fridge.
61cubby is offline   Reply With Quote
Old 07-29-2015, 04:40 PM   #15
Evereddie's Avatar
The bottom line is what is the actual voltage with it running. If 104 or lower best to stop it from running and beef something up. Running the unit on too low a voltage will cause overheating and premature failure.
There are 10 types of people in the world.
Those that know binary, and those that don't.
Evereddie is online now   Reply With Quote
Old 07-29-2015, 04:58 PM   #16
Crockett's Avatar
Id prolly tap out at 108, maybe 106. the 100 footer 12ga prolly wouldnt make it here tomorrow at 113 degrees just run the voltmeter in a plug in the coach and see...
air conditioner
