if you have checked the drain and it is clear then it could be the seal that the A/C sit's on when it is sandwiched between the roof and outside
or it could have come loose and leaving a gap which is why they are saying to check the mounting bolts
from the inside pull the cover off and check the bolts to see if thet are tight
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
