Old 09-13-2015, 08:51 PM   #1
Always something ... Interior Ceiling lights stopped working
I had the lift switch fail in the down direction. I figured it out by checking the volts at the switch and noticed that there wasn't any volts getting past it. So I ordered one that matched exactly as the OEM (DPDT, 20AMPS@125v, 10A@277V, rated for 1.5HP motor). $12 from amazon and other couple bucks for the weather proof jacket for the lever. I just replaced it on this last weekend's camping trip. Not only does the lift go down, but it also goes up faster. Maybe it had some resistance within the switch itself.
But now the interior roof lights are not working. First I checked the master switch at the entrance corner. Not getting any volts there. I also checked the fuse-converter panel and the fuse for that circuit was good. However, I wasn't getting any volts from the hot side of the fuse. So, I guess the fuse-panel itself is bad?
The two floor lights work, so I guess their on another circuit? The panel is loosely documented to what goes where. Is it common for these panel-converters to have bad legs/feeds?
FYI - I replaced the switch "after" noticing the interior lights not working. So, not relating but electrical gremlins are alive and well ...
2013 Forest River Rockwood Highwall 296
1991 Chevrolet Suburban V2500
gpwooden is offline   Reply With Quote
Old 09-14-2015, 07:07 AM   #2
f5moab's Avatar
The WFCO converters that come with popups are not noted as being one of the best out there.
I know when mine goes, I will probably replace it with a Progressive Dynamic Power Center.
f5moab is offline   Reply With Quote
Old 09-14-2015, 08:11 PM   #3
Yeah, that Mighty Mini looks decent. I may just pay the $50 deductible for the service charge and see if it can just be replaced under my service contract, assuming that is the problem. I can't see how it can't be in this case. Luckily the floor lights worked and we had a couple flashlights. Made for an interesting night with the kiddos.
Old 09-14-2015, 09:38 PM   #4
Check the switch, usually buy the sink /stove fold down, it shuts the lights off when the sink cabinet is folded and shuts the lights off so they will not burn the canvass if they are hot.
2002 Rockwood Freedom 2318G
2004 Ford F 150 5.4 liter
3 Chihuahuas Sammy, Delilah,Gypsy
nineoaks2004 is offline   Reply With Quote
Old 09-15-2015, 07:38 AM   #5
I appreciate the reply, but this is on a highwall model - so the sink cabinet doesn't fold, it's stationary. However, there is a light-switch for ceiling lights - its the one pictured below with the red arrow. That was the first place I checked too, thinking it was a bad switch (since I have been dealing with a bad switch with the lift). I also checked the hot side of the circuit at the panel and not getting anything there as well, so I am thinking that the circuit itself is bad?
Also pictured is a green arrow, which is the floor lights switch. That works just fine, so that must be on another circuit. The documentation surrounding this is pretty much non-existant so I guess I will just pay the service claim and get it looked at and see if the panel can be covered.
Old 09-15-2015, 07:53 AM   #6
clr
If you checked the circuit and have no power at the panel then I would start looking at the panel. You may have popped the circuit breaker for that circuit. Try turning off all the circuit breaker to reset them and then try turning them all back on.
clr is offline   Reply With Quote
Old 09-15-2015, 07:59 AM   #7
Yeah, already flipped the 30-AMP master and the 15/20AMP subs to no prevail. I am wondering if I should just wire in a Progressive Dynamic panel and just call it done. Just curious if these cheaper WFCO panels were known for this type of issue. I am sure the repair place will just put in the cheapest unit that they will find.
Old 09-15-2015, 12:41 PM   #8
BobHanke's Avatar
Check your 12V fuses in the main panel. One could be blown or the connection might be corroded.
BobHanke is offline   Reply With Quote
Old 09-15-2015, 02:01 PM   #9
Send a message via Yahoo to Magee
Could there be a tripped GFI somewhere? My RV (totally different) has two, one near the cook stove and one in the bathroom.
Magee is offline   Reply With Quote
Old 09-15-2015, 02:20 PM   #10
BobHanke's Avatar
Sorry, GFI's are normally only on lines with outlets....not lights. However, it is always possible that someone might have added some "home touches".
light
