Old 03-09-2015, 01:48 PM   #11
Originally Posted by f5moab View Post
3604 - Camper Leveler
I also plan on installing a large level (I believe it is 11 inches) on the front of the trailer, so that after placing the camper leveler under a tire, I can then back up and view in the rearview mirror when the trailer is leveled side-to-side. Then lock down the parking brake and go out and chock it and disconnect the trailer from the TV.
So...anyone have any experience with either of these product?
Thanks.
I installed a 6" bubble level that is calibrated in inches on the A-frame front (found in my RV dealer store), similar to what you have in mind. When I'm approximately in position, I check the level, and pull out the number of Leveler blocks (the orange Legos, 1" rise per block) I need, and back on to them. Works like a champ (very cheap, total cost less than $40) for me. Also very light and compact.
Fred W
Old 03-09-2015, 03:26 PM   #12
Timex's Avatar
First off, let me say that I have levels on the side and front of my trailer. Of course with my v nose, it's hard to put a level on the front so I placed it on the tongue. I had levels on my previous 2 trailers as well. I tend to overthink things, so I have a question:
How do you know, when you attach the level to the side/front or where ever, that the level is level?
Yea, you can measure and line it up with trim or a groove in the siding. If you really want to get technical, measure from the ground up and set the levels. What if the walls and roof aren't square?
For me, if I get it close, I'm happy.
2012 Flagstaff V Lite 30 WRLTS
2005 Dodge Ram 2500 5.7 Mag Hemi 3.72 Rearaxle
Nights camped 2015 = 23
Nights camped 2016 = 25
Nights camped 2017 = 13
Nights camped 2018 = 3
Timex is offline   Reply With Quote
Old 03-09-2015, 03:39 PM   #13
Just level the floor of the camper front to back and side to side and then attach the level to a special made bracket on the front of the V where you can see it from the TV. Might take a while to get it level, but the time you spend mounting the level will be more than offset at campgrounds in the future.
Old 03-09-2015, 06:13 PM   #14
f5moab's Avatar
^^^ What he said. I have levels now on the front frame, side frame and left rear/rear rear side frames (these are for leveling the trailer with the BAL leveler on the left side).
The one I plan on putting on the front is a 11.5 inch level that can be seen through the rear view mirror as I back up on the andersen block.
f5moab is offline   Reply With Quote
Old 03-10-2015, 01:29 PM   #15
Since I store the A122 in the garage, I carefully leveled in the garage using a carpenter's level on the frame, and on the folded down roof.
After I was satisfied the camper was level, I installed the bubble level on the camper, adjusting it to read zero. So far, the calibration is right on, as I cannot detect any slant while we are camping and the bubble shows level.
Fred W
2014 Rockwood A122
2008 Hyundai Entourage
Old 03-10-2015, 01:39 PM   #16
camper1999's Avatar
Originally Posted by OldCoot View Post
If you have a tandem axle, you will need two. I had to cut the corner off mine to be able to get them between the tires. I have since ground the 45 corner down to make it the same distance from the big cutout as it is on the side and bottom to make it even easier to install between the tires.
X2 best investment I made. I love these things.
2011 GMC 2500HD Diesel
camper
