Old 05-12-2014, 06:40 PM   #11
Originally Posted by dfskinner View Post
and when you check the water levels be sure to use "distilled" water.....
I was told to use holy water. That's probably why my batts last forever.
2014 Georgetown 351DS
-TruCenter -Front/Rear CHF -Hellwig Links -Tiger Trak -Ran McNally GPS -ScanGauge -Truck Systems TPMS -5 Star Tune
alparmer is offline   Reply With Quote
Old 05-12-2014, 08:22 PM   #12
battery disconnect
I noticed the power lift switch is not protected- so I am thinking when the pup is closed an accidental turning on will damage lift system? For good measure I am keeping positive lead disconnected from battery. Like my boat battery, I plan on charging before heading out each trip. Anybody figure out a way to disable switch to prevent accidental switching? Sorry I am an official rookie.
2012 Rockwood 1940ltd
2004 GMC Sierra 4x4
Ringbill is offline   Reply With Quote
Old 05-12-2014, 08:30 PM   #13
f5moab's Avatar
You could make it part of a disconnect switch; add a fuse inline from the circuit breaker (at the battery B+ post) and the motor and remove the fuse when not in use, or as you are doing, disconnect it from the battery. (I just remove the batteries.)
f5moab is offline   Reply With Quote
Old 05-12-2014, 08:50 PM   #14
Dealer told me if it's sitting longer than a week to disconnect the negative.
Sent from my SCH-I545 using Tapatalk
ESDSKeith is offline   Reply With Quote
Old 05-16-2014, 07:09 AM   #15
batt
I went ahead and unhooked both the positive and negative cables from battery. By the way, ESDSKeith, the battery that came with my 2012 1940 is ok but I plan on replacing it in a couple of months...I believe it is some generic brand 850 CCA RV/Marine type...I would welcome any suggestions for a replacement. (On my boat I've had good success with Delco and the Auto Zone marine- the truck has an Interstate that lasted 4 years in the Florida heat)
2004 GMC Sierra 4x4
Old 05-16-2014, 07:41 AM   #16
DaveSchwartz's Avatar
I've had the same dual Interstate Marine/RV batts for 9 years and can't tell them from new.
Its always on shorepower during the camping season, in the driveway or camping. After the last trip in the fall, I remove them to my unheated garage where they sit on a small automatic battery maintainer inside a box of 1" pink styrofoam board to hold their little bit of self-generated heat.
2015 Rockwood Signature UltraLite 8282WS Platinum, GY Marathon LRD, TST 507RV TPMS
2005 GMC 2500HD CCSB D/A, Curt E16, Prodigy P2, Garmin RV760LMT w/BC-20 b/u cam
Self restraint is for the young. I'm old and want it NOW!
DaveSchwartz is offline   Reply With Quote
battery
