Old 07-17-2012, 08:33 PM   #21
Blackrock's Avatar
Traded my pop up in last week but it had the dometic manual awning on it.
To deploy the awning unroll it and let it hang down. then pull the support poles out(they twist-lok) and on mine there were sockets on the side of my trailer that the black ball end snapped into. These are at a 45 degree angle to the trailer. Then the main poles that extend and lock with little buttons. These were the vertical supports and had 'D' rings on the bottom that can be staked down. The two sets of poles store in the outer edge of the awning. Hope this helps.
2016 RAM 1500 - 2016 Keystone Laredo 265SRK
The road goes on forever and the party never ends.
Blackrock is offline   Reply With Quote
Old 07-17-2012, 08:36 PM   #22
spierce617's Avatar
I use to have a Starcraft with the same system. Mine had two plastic clips that were on the side of the trailer. On the bottom of the poles that you have against the trailer there was a plastice cover that pulled off to expose a ball type that went into the plastic clip on the trailer. You may not have the plastic clip installed as they can break or they were not installed. I have attached a picture. You can see the plastic clips on the side of the trailer just below the canvas. They are black and partially covered with the canvas.
Name:	IMG_0590 (Medium).jpg
1999 Chevrolet Suburban 5.7L V8
2005 Cherokee Lite 28A
spierce617 is offline   Reply With Quote
Old 07-17-2012, 08:38 PM   #23
VinceU's Avatar
Wow looks like we have it! There's most likely "sockets" mounted on the top of the hardsides that were left off or broke off. The coleman experience was correct in poles to the ground, just a brand choice difference. Have it your way! Looks better on the camper and more functional, just no sockets provided on them. Happy Camping!
Old 07-17-2012, 08:50 PM   #24
Will talk to my dealer about my missing sockets! Thanks for all the help -and we are have been having very Happy Camping! Absolutely the best family time.
yyccarla is offline   Reply With Quote
Old 07-17-2012, 09:01 PM   #25
sherdep's Avatar
was looking on youtube and found one mounted
picture attached
2270 freedom
and i put red lines on where yours should attach
hope that helps as well
Name:	Freedom 2270 Popup.JPG
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 07-17-2012, 09:19 PM   #26
There are youtube videos with awning setup demonstrations that show locations of sockets.
oldbear is offline   Reply With Quote
awning
