Old 03-02-2015, 08:12 AM   #31
GalsofEscape's Avatar
Agreed kinma
HTT: "EscapeII" 2016 Shamrock 23WS (current)
PUP: "Escape" 2010 Rockwood HW 277 (gone)
TV: "Bruce" 2011 Dodge Durango V8 Hemi Crew
Just us gals (me, Sis and our daughters)
We spend alot of money to go sit in the woods
GalsofEscape is offline   Reply With Quote
Old 03-02-2015, 09:04 AM   #32
The only thing I cab think of is if some how you could mount through the support arms but then what would you do about the safety supports? Oh well just dreaming I guess. Maybe I'll try the next FR weekend at Goshen IN and start a conversation. US HW owners need something maybe even one like a Hi Lo TT have.
kinma13 is offline   Reply With Quote
Old 03-02-2015, 09:08 AM   #33
rd3
rd3's Avatar
The one I used was the A&E Catalina 2500. Here is a link to the installation manual. I don't recall it being much heavier than the bag awning that it replaced.
http://www.scamptrailers.com/images/...alina_2500.pdf
If you can't open the link you can Google it and find a few copies. I had the 12' one.
Found the weight to be from 39 to 55 lbs depending on what size you get.
Not sure if they are still making them
rd3 is offline   Reply With Quote
Old 03-02-2015, 09:13 AM   #34
I think that would work maybe with a little fab work.
Old 03-02-2015, 09:39 AM   #35
May not be available, I only see replacement parts for them. And the existing trimline awning is listed at 17 lb. So these are a bit heavier. the dometic 8500 seems to be very similar to the catalina and is listed at 46 lbs.
Old 03-02-2015, 10:04 AM   #36
Yeah agree.
Old 03-03-2015, 10:02 AM   #37
I asked the forest river/Rockwood rep and he said there is no other awning for popups and that the 8500 would not work as it has those vertical supports. The weight limit of the roof is 400 lbs, but he did not answer my question on whether or not there was a weight limit for the awning or if the awning weight would effect the function of the roof.
Old 03-03-2015, 10:48 AM   #38
Thank you. I'm thinking the weight leverage at extention out till legs were down wound hurt the roof cause being off level can affect the door alone.
Old 03-03-2015, 10:55 AM   #39
I asked about the Dometic 9500 which is self supporting and does not have the legs but its at 90 pounds. he said that definitely would not work because the pop-up roof does not have the structure needed to support the mounts for that kind of awning.
Old 03-04-2015, 10:19 AM   #40
vinmaker's Avatar
90lbs? Wow those things are heavy.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 1000#
awning
