Old 07-11-2019, 03:31 AM   #1
Battery Disconnect or Power winch turn-off on Rockwood High Wall hw277
Can't seem to find this info online. Trying to figure out how to disable the power winch switch on our new 2020 high wall HW277. We have a 3 year old who will definitely flip the switch and try to pop up or down the camper when we don't want him to.
Any way to disconnect this switch? Or better yet, i think my husband wants to find a way to disconnect the battery all together?
Jendiehl530 is offline   Reply With Quote
Old 07-11-2019, 07:10 AM   #2
backpacker3's Avatar
Yes, you can install a battery isolation switch. It is an easy install. But, if you are camping, not a good idea to use isolate battery, no 12v power.
You can also buy a single pole on/off switch and install it inline with the power winch power line and mount it out of the way so your child can' see it. Never have tried it but should work. If you have an inline fuse on the power side, you can also just pull the fire when not needing the power roof.
Maybe others will have some input for you. Good Luck.
2019 Flagstaff 206STSE
2017 Chevy Colorado Z71 4x4 V6
backpacker3 is offline   Reply With Quote
Old 07-11-2019, 07:30 AM   #3
Try something like this- https://www.delcity.net/store/Master...BoCmYkQAvD_BwE
You could create a separate circuit to your winch, install this inline, and switch off/remove “key” until ready to raise/lower.
Obviously, kids are smart, observant, and will do their best to overcome “obstacles” like finding a key. Heck of a thing to lock up a key to lock off power.
Camping is worth most any level of effort.
2018 Surveyor 264RKLE
Retired
Jeffjeeptj is offline   Reply With Quote
Old 07-11-2019, 07:42 AM   #4
GalsofEscape's Avatar
Just take the wires off the battery terminals.
HTT: "EscapeII" 2016 Shamrock 23WS (current)
PUP: "Escape" 2010 Rockwood HW 277 (gone)
TV: "Bruce" 2011 Dodge Durango V8 Hemi Crew
Just us gals (me, Sis and our daughters)
We spend alot of money to go sit in the woods
GalsofEscape is online now   Reply With Quote
Old 07-11-2019, 10:56 AM   #5
On my 228D's battery there are TWO wires with their own crimped on ring on each terminal, one is for the camper power, and the other is for the winch. The winch positive one on mine has a circuit breaker inline and is easy to spot from the camper power line. Perhaps just unhook that when the roof is fully deployed? I put wingnuts on mine so I can easily disconnect the battery to prevent drain when not in use.
flyerdp is offline   Reply With Quote
battery, battery disconnect, power, rockwood
