Old 04-16-2014, 06:04 PM   #1
delb2917's Avatar
Battery.... first time dry run
Just pulled pop up in driveway and put the inline fuse in and tried to use electric lift and battery is dead. Have pop up plugged into truck and have battery on trickle charger. How long do I have to wait till I can get juice to battery to put up the roof???
Sent from my SCH-I535 using Forest River Forums mobile app
delb2917 is offline   Reply With Quote
Old 04-16-2014, 06:14 PM   #2
Herk7769's Avatar
You have the battery out of the pop-up and on a dedicated charger?
If so, it would depend on the Amp Hour Rating of the battery.
Dedicated chargers have "stages" of charge (based on the battery's ability to take and store the incoming electrons). Initially, the battery has lots of room on the surface and the voltage builds up quickly. However as the plates fill, electrons on the surface must be "pushed" into the lead. This takes more energy and time. The charger will detect this increase in voltage and step up the charging voltage and reduce the rate that electrons are introduced to avoid "boiling" the electrolyte.
You should be able to use the battery within an hour or so, but to be fully charged, you would need to keep it on the charger for many hours (like 16 to 24 hours).
I also attached an article on why automobile alternators make terrible deep cycle battery chargers.
Name:	battery voltage and capacity Curve.jpg
File Type: pdf Automobile Alternators as Chargers.pdf (805.9 KB, 16 views)
HAM CALLSIGN - KC3FFW
Old 04-16-2014, 06:18 PM   #3
delb2917's Avatar
Well I have it plugged into a little trickle charger now. Not plunge in to the truck anymore. So probably an hour or so to be able to lift my roof?
Old 04-16-2014, 06:25 PM   #4
Herk7769's Avatar
Yes, unless you were very unlucky and the battery froze while discharged. In this case it is very possible a plate cracked and shorted out inside.
Here is a table of freezing points of partially discharged batteries.
As you can see a "mostly" discharged (less than 20% remaining) battery will freeze at 19 degrees Fahrenheit.
Old 04-16-2014, 06:29 PM   #5
delb2917's Avatar
Unfunny. Well this would be the third battery. The one that was on the camper when I bought it was dead. And then when he was showing how the auto lifts work it didnt work so he changed the battery out with a new one. Now if this one is done then there might be something else wrong with this pop up.
Old 04-16-2014, 06:44 PM   #6
delb2917's Avatar
Okay I took battery out because I checked my trickle charger and the trickle charger said to check battery so I'm going to take it up to autozone and have them check the battery to see if it's dead if it's not then I guess I have to manually lift the roof up and check my fuses inside my pop up maybe there is something that's blowing inside the popup. Any other suggestions for me would be very very helpful. Thank you very much.
Old 04-16-2014, 06:45 PM   #7
bikendan's Avatar
after 3 batteries, why haven't you installed a battery disconnect switch, so the battery doesn't get depleted by the parasitic power drains?
i installed one in my hybrid TT and after 4 months of storage, the batteries were still nearly fully charged.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 04-16-2014, 07:11 PM   #8
Herk7769's Avatar
I don't own a pop-up, but you should be able to plug in the camper to shore power and the converter should operate the lift motor.
With a shorted battery installed, the converter will NOT power up.
Without it installed; it should.
Ditto on the disconnect.
Old 04-16-2014, 07:57 PM   #9
delb2917's Avatar
Well guys I had to buy a 100.00 battery. Will be calling dealership fist thing in the morning. Will look into quick connect for battery. Now one last question. Lol I want to use my heater. Were the hell is the thermostat at? I really feel like a idiot. I have a 2012 forest river mac pop up.
Old 04-16-2014, 08:17 PM   #10
delb2917's Avatar
Found it. Sorry
battery, first time
