Old 05-14-2016, 06:00 PM   #11
Battery or not?
Hi Fred, thanks for the thoughtful answer.
Ok, I set the pup up for the first time today, and what did I find? A tiny little battery! Sits in a box attached to the tongue. It's about 3x5 inches, says its 12 volt. That's all I can read on it.
I have a seven pin connector, and had my hitch guy put a seven on my TV.
I have electric brakes, heater, water pump and fridge.
I flipped the 15 amp breaker, and I had power to outlets. (Extension cord from the house, adapter, 30 from the pup.)
Plugged in a lamp and got light. But also got constant intermittent buzzing from the converter. Not the hum, that was there all the time, not intermittent. Sounded like some kind of warning alarm?
I did get ceiling lights, so I guess I'm also getting 12 V power. Didn't try the water pump or the fridge. Not that daring yet.
Leetch94 is offline   Reply With Quote
Old 05-14-2016, 07:14 PM   #12
Update all your fellow replys....leach94.....hmmm. that name is a little odd.....like seriously....
2008 Nissan Frontier 4x4
2011 Rockwood A122
D-mo is offline   Reply With Quote
Old 05-14-2016, 07:17 PM   #13
I have no idea what you mean.
Update what?
And it's leetch94.
Old 05-14-2016, 08:31 PM   #14
That little battery is to power your brakes should you lose the PUP off the hitch. There should be an emergency break-away cable - usually a thin piece of plastic-coated wire attached to a plastic plug. When that plug is pulled out in an emergency by the cable, that little battery activates the brakes on your PUP.
Sounds like you got every major option except the battery and battery wiring. You will want the battery if you ever want to camp without a power hook-up. Everything you have will run off the battery or propane.
How much dry camping or boondocking you do, and for how long, will determine how much battery you need. As I said before, the heater and your lights are the big power hogs. Replace the interior light bulbs with LEDs, and the lights go to not very significant (from 2.2 amps per light to 0.75 amps per light or less). The heater fan typically draws about 4 amps. The little PUP fridges use nothing when on propane. And the water pump doesn't run for long enough to matter.
A single size 24 deep cycle battery (about the smallest common size) weighs about 60lbs (adds to tongue weight), and will let you run your heater for about 8 hours (run time) along with other small loads before your battery drops to 50% charge. If you run a deep cycle battery below 50%, its remaining life drops significantly.
Since we live in Colorado, and wanted to camp anytime there's not snow on the ground and night temps are high 20s or above, we need the heater for 4 nights or less on a long weekend. We needed 2 batteries to do it. I switched to two 6V golf cart batteries after I had a failure of one 12V. The golf cart batteries were cheaper, fit in the same box, and gave more capacity.
Your converter is working, but may be on its way to failing or just plain noisy. The converter is supplying the 12V when you plug the PUP in. I would seriously consider replacing the converter in the near future with a decent 3 mode converter, especially if you are going to install and use your battery.
The fridge should be normally operated on 120V AC when you are plugged in, and on propane when you are not. The only time I put the fridge on 12V is when I'm towing. The minivan supplies the 12V for the fridge while I'm towing. PUP fridges cool much better on propane or 120V, and usually cool best on propane.
Hope this helps some more...
Fred W
2014 Rockwood A122 A-frame
First photo is a battery cutoff switch I installed to save disconnecting battery while camper is not in use. I made wood cover for battery box because plastic one blew off and away while towing. Note emergency disconnect on bottom of frame (left bottom corner). Make sure you have one wired in.
Second photo shows the two golf cart batteries inside the box.
Third photo shows outside vent covers for fridge removed. Green switch in upper compartment turns fridge on AC. Dial selects how cold. Red switch puts fridge on 12V DC (there is no coldness control on DC). Bottom section has propane controls. Propane on is knob with red dot (push while lighting). Red push button is igniter. Cold control is left knob.
Final photo shows tongue jack, propane tanks, and battery box. Not much extra room. Display is remote readout for wireless thermometer I stick in fridge. Fridge is NOT thermostatic controlled.
Name:	battery cutoff switch 23Apr2016.jpg
ID:	107905   Click image for larger version
Name:	dual 6V battery install 25Apr2016.JPG
ID:	107906   Click image for larger version
Name:	fridge mod 04 23Apr2016.JPG
ID:	107907   Click image for larger version
Name:	plastic propane bottle cover 23Apr 2016.JPG
Old 05-14-2016, 10:34 PM   #15
bikendan's Avatar
So these popups that have no provision for a 12v battery, can only be used where hookups are available?
I just don't get why a popup like this exists.
You've got electric brakes, fridge, furnace, lights, fan that all run on 12v power but we're not going to have any connections for a 12v battery!
CRAZY!:what:
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 05-15-2016, 06:13 AM   #16
If you study the option list carefully, the brakes, fridge, and furnace were all options - as was the battery and wiring. A fan was not part of the OP listed equipment. Only the lights (it's probably only one overhead light) needed 12V on the standard model. You needed hook-ups for any 12V stuff.
The water pump may or may not have been standard - my first PUP had a hand pump at the sink, as have my sailboats. I always replaced the hand pumps with a foot pump, which I actually prefer to a 12V pump. Unfortunately, the outside shower and hot water heater (nice conveniences) on my later PUPs and A-frame made a foot pump impractical.
The particular model PUP that OP bought (and this is not an insult to the OP) was the very lowest-price PUP that Rockwood produced in 2006. So normally standard features on higher-end models were options on the LTD.
When we group camped at Lake Tahoe every summer, I had a little bit of envy for the families with the base 8ft PUPs. So simple, so easy to maintain, and so light to tow. We had a 12ft box Coleman Westlake that had an inside shower/cassette potty that we paid for but never used, and an outside shower we paid for but never used. We had to use coolers stored in the bear boxes instead of the fridge because of the bears, and we mostly used flashlights to preserve the battery for the 10-12 days. And when the battery was finally dead, we couldn't pump water from our water tank - hand pumps and foot pumps work with a dead battery. Except for the extra room to sleep more kids, our bigger PUP gained us nothing and cost us more.
I did remember our camping style when we bought the A-frame - except now all the fancy stuff is standard. The camper is a very nice bed for the night (mattress toppers needed), and the dinette works to wait out a rain storm. The rest of the time is spent outside - cooking, eating, clean-up, lounging, sight-seeing, hiking, etc. I finally found a use for the outside shower and hot water heater - supplies easy-to-access hot water for dish washing at the picnic table. The stereo, inside stove, and mattress warmers are never used. We do use the air conditioning and microwave if we have hook-ups.
Different camping styles for different folks.
Fred W
2014 Rockwood A122 A-frame (base model)
Old 05-15-2016, 06:33 AM   #17
Maybe it is a "Nostalgia Model" with "Gas lights and Ice Box"? Youroo!!
Old 05-15-2016, 12:42 PM   #18
My Coleman came with fridge, furnace, no brakes, no battery. Everything on the pup ran off 12VDC from the converter. There were 2 outlets with 120VAC for plugging stuff in.
Also be careful with pgandaw"s statement: "The fridge should be normally operated on 120V AC when you are plugged in, and on propane when you are not." Not necessarily true. The fridge on my Coleman actually only ran on 12VDC or propane. It ran on 120VAC only via the 12VDC from the converter. So it was really only a "2-way" fridge (12VDC/propane). There ARE apparently "3-way" fridges that actually use 120VAC/12VDC/propane. Make sure you fully understand which kind you've got and what it really can use to power it.
2011 Traverse LT, 3.6L, FWD
battery
