Old 05-11-2015, 11:35 AM   #1
macshane's Avatar
Bed End Support Location
A question the DW didn't want to ask because she did want to appear stupid. I, on the other hand, don't care.
On the bunk support brackets,which of the three frame holes is used? One more than the other? Different one for different situations?
macshane is offline   Reply With Quote
Old 05-11-2015, 12:44 PM   #2
Not a dumb question. Nor even my dealer could tell my!! Lol. I use the top I beleive. Haven't set it up in months. I believe the brackets are used by ALL pop up models so it would be different depending on ur pup. Mine is a hw276. I was told to use what ever hole makes the beds level or closest to level. But I try ed that and at one site the supports weren't even close no matter the hole. Following
kinma13 is offline   Reply With Quote
Old 05-11-2015, 01:45 PM   #3
2gwright's Avatar
My HW296 uses the bottom holes.
2gwright is offline   Reply With Quote
Old 05-11-2015, 02:17 PM   #4
Ok just looked at some pictures of setup last yr mine are in the center hole
Old 05-11-2015, 02:50 PM   #5
vinmaker's Avatar
I concur.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 05-13-2015, 10:01 AM   #6
loumichelle735's Avatar
Center as well on the front. Our rear bracket has 4 slots and we use the second from the bottom there. Whatever keeps it level and well supported. We have a 2318g.
loumichelle735
Columbia Pa
2014 Rockwood 2318g
2010 Ford Escape
loumichelle735 is offline   Reply With Quote
Old 05-13-2015, 01:57 PM   #7
I use the bottom front and rear, I just figured they should be level too, so I leveled the camper, then put a level on the supports and picked the best one.
'14 Rockwood 2318G
'03 Ford Explorer
gruss01 is offline   Reply With Quote
Old 05-13-2015, 07:37 PM   #8
f5moab's Avatar
When I picked up the trailer, the dealer noted where the lower support bars were inserted. He said the way they determine it is by using the highest slot, then pull the bed out and if there is any resistance, drop down to the next slot, etc.
He said the when the trailer is assembled there is a variance plus the support rods can have a small variance too.
For me it was the center for the front, and the second from the bottom on the rear.
f5moab is offline   Reply With Quote
Old 05-19-2015, 05:02 AM   #9
macshane's Avatar
Thank you all. I put a level on it this weekend & our HW27KS needs to be in the bottom holes for the front bed. I haven't checked the rear bed yet.
Old 05-21-2015, 05:53 AM   #10
I currently use the middle one on my 2514G
*2015 Rockwood Premier 2514G
*2012 Chrysler Town & Country
w/ weight distribution & anti-sway
Days Camped:
2013: 24 2014: 3
MrThursdayNight is offline   Reply With Quote
bed, cat, location
