Old 08-19-2013, 03:05 PM   #1
Bed Slideout Jammed
One my sleep slide outs on my Rockwood 2280 tent trailer is jammed. I believe the bed rails are slightly bent. Are these repairable or replaceable?
Thank you for your reply.
kennygsr is offline   Reply With Quote
Old 08-24-2013, 08:59 AM   #2
Bennett5's Avatar
I don't know about repairable, but check a few things first, is it going in straight? If they get pushed on one side they tend to lock up. Need to pull all the way out and try again. This has happened to us a few times. The other thing to check is the mounting bolts for the back roller, make sure they didn't come loose and fall out and the roller is still in place and rolls freely. These have a tendency to come loose and it's extremely difficult to get the bed in if they are missing or not rolling correctly.
Hope that helps, good luck.
Bennett5 is offline   Reply With Quote
Old 08-26-2013, 07:57 PM   #3
I am having the same problem but i know for a fact that it is because mine are bent, i have checked the rollers and all. I too am looking for replacements. Any suggestions?
Sappy85 is offline   Reply With Quote
Old 08-26-2013, 08:21 PM   #4
Garrette's Avatar
If there is one think I have learned is that RV builders do not make anything. Look on your rails for any info no matter how slight.. Get on line and start searching. Search this portal as well as http://www.popupportal.com/
Good luck.
Garrette is offline   Reply With Quote
Old 08-26-2013, 08:46 PM   #5
Thank you i'll check it out
bed, slide, slide out
