Old 11-02-2014, 01:42 PM   #1
Bed slides
What do you use to help your beds slide in and out easier?
kellieh04 is offline   Reply With Quote
Old 11-02-2014, 01:56 PM   #2
Done with this
Dry silicone spray only. Also use this on the lift poles on each corner. There are also grease fitting to lube on the lift mechanism underneath.
I'm a little too truthful, I guess.
Y'all have fun in "Fantasy Land".
4mula1fan is offline   Reply With Quote
Old 11-02-2014, 01:58 PM   #3
Can I get that spray at Camping World?
Old 11-02-2014, 02:33 PM   #4
Done with this
Probably. Make sure it says "dry spray silicone." I've seen it at department, home improvement stores too.
Old 11-02-2014, 02:44 PM   #5
Thank you very much!
Old 11-02-2014, 02:47 PM   #6
RKR
RKR's Avatar
As mentioned above , Lowes , HD, Wal Mart or any auto parts store will probably be cheaper. They don't have the "RV" mark up.
Sent from my high tech gadget
RKR is offline   Reply With Quote
Old 11-02-2014, 02:55 PM   #7
Thank you for the great tip.
Old 11-03-2014, 10:44 AM   #8
Something like this: Amazon.com: Liquid Wrench L512 Liquid Wrench Dry Lubricant with CERFLON - 11 oz.: Automotive
You can find it anywhere though don't have to order online
'14 Rockwood 2318G
'03 Ford Explorer
gruss01 is offline   Reply With Quote
Old 11-12-2014, 08:47 PM   #9
Menards sells it as well.
KamperKen1967 is offline   Reply With Quote
bed, slide, slide out
