Old 05-09-2016, 04:08 PM   #1
Dutchmen's Avatar
best way to seal leaky roof fan exhaust
so this weekend I discovered (with the help of a lot of rain) that my fan vent on the roof has a leak. Never should happen on a 2015 model. But I need to fix it correctly. I know there are a lot of products on the market; from spray sealant to different types of caulk & silicones. I just want to scrape all the original silicone & re apply something new. Can anyone suggest what may be best? It is a very slow small leak, but you know water.....it doesn't take much to cause considerable damage to the inside of your PUP> Thank you.
Dutchmen is offline   Reply With Quote
Old 05-09-2016, 04:15 PM   #2
EternaBond
Old 05-09-2016, 04:26 PM   #3
crunchman12001's Avatar
Originally Posted by Wiscampsin View Post
X2
2015 F-250 FX4
Old 05-09-2016, 05:06 PM   #4
Pro Flex RV Sealant. Very good stuff and available at most RV dealers.
http://www.geocelusa.com/product/all...nt-detail.html
spurticus is offline   Reply With Quote
Old 05-09-2016, 10:01 PM   #5
Dutchmen's Avatar
Thanks, I will review both and make my decision.
Old 05-10-2016, 11:39 AM   #6
leak
x3 for eternabond
I just installed 2 vents. the eternabond is not the prettiest, but will not leak.
you can also use Dicor Self Level. it works great also
bbaker2001 is offline   Reply With Quote
Old 05-10-2016, 04:59 PM   #7
rsdata's Avatar
eternabond tape, right over your existing caulk, which should be cleaned before application... comes in 1,2 and 3 inch widths
2014 Shamrock 183
2014 RAM 1500 Bighorn Crew Cab, HEMI, 3.21 gears, 8 Spd, 4X4
rsdata is online now   Reply With Quote
Old 05-10-2016, 06:44 PM   #8
Dutchmen's Avatar
I was entertaining the tape. I just hope it's a clean look. My top is beige. So I may not like the color contrast. Thanks for the suggestions guys
Old 05-10-2016, 06:45 PM   #9
my tape is 4"
Old 05-10-2016, 08:34 PM   #10
Pickin' & Campin'
They make beige EternaBond tape. I have both 2” and 4”.
Days Camped: '15=22 '16=46 '17=30 '18=4
fan, leak, roo, roof
