Old 09-24-2014, 01:23 PM   #1
Question bi-pass valve
Hey all, getting ready to install a bi-pass valve on my HW31 Forest River Flagstaff pup, and was wondering if anyone had a problem with the water flow after putting one of these on? This valve is for easy winterizing and hooks to the pump. Thanks
caver is offline   Reply With Quote
Old 09-26-2014, 03:45 PM   #2
vinmaker's Avatar
Hey Caver.
I have not installed one of these. I usually just crawl underneath and disconnect the hose from the FW tank since this is the hose that is connected to the pump. I then stick it in a gallon of RV antifreeze and draw it up into my system.
I did notice on my new unit that they used those new water pipes and clamps. The old one had a simple pipe clamp. I will have to cut the clamp off and then re affix it with a pipe clamp when I am done.
You definitely have a good idea if you do not mind doing the work.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 1000#
