07-05-2018, 10:11 PM
#21
Just as confused as you
The 20 volt 1/2" Dewalt impact I have will sheer off a 1/2" bolt easily. I've done it several times at work. I don't think I would want to try it on my stabilizers. Though I don't know the torque output or the hp of the 12vdc motor on my stabilizers, it stops as soon as it gets pressure on the stabilizers.
Richard & Jill
07-06-2018, 07:10 AM
#22
You can purchase a one piece socket/driver made by camco for about $5-6 - an impact driver would make a whole lot of noise and overkill- a drill works just fine
07-06-2018, 08:32 AM
#23
We are talking about pop-up trailer here. Not a 40' fiver. It probably came with something like this to crank down the stabalizers:
If you can get them down with this thing, any cheapo drill with do the job. My parents had a pop-up and used an old 9.6v Makita drill and it worked just fine.
07-06-2018, 12:08 PM
#24
Most of us understand that. Some of us were responding to what Kimber45 said in post #4 about using a impact wrench instead of a drill.
BTW, my 36-1/2 ft TT weighs just over 9k. Besides being able to remove the motor and using the crank with a splined coupler on it there is also a nut on the opposite end to use a socket.
Richard & Jill
07-06-2018, 12:29 PM
#25
I use a 18 volt Ryobi that I bought off craigslist for 10$ works great and if I set it for full toque it will lift the fifth wheel off the ground.
By the way I bought two sissors jacks from Harbor Freight that are rated for 10000lbs each so yes they will lift it.
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
07-08-2018, 01:40 PM
#26
You can get a socket in most camping sections at stores. Keep them lubed and a cordless drill will handle them no problem
07-08-2018, 01:47 PM
#27
Or any auto parts stores (more of them around).
2011 Traverse LT, 3.6L, FWD
07-08-2018, 02:15 PM
#28
I have a DeWALT at home along with an impact but on the road, I have a Ryobi drill. It will drive my stabilizers down with enough power to lift the front. The batteries run a fan for the beach, a leaf blower for the patio mat and a Ryobi air compressor to top off the tires.
07-08-2018, 02:42 PM
#29
Man, everyone beating up on using an impact gun. My impact produces the same the torque as any drill mentioned from 12V to 20V. A whole lot more if I let it, but I don't go there. If you know your gun, you know how many "braps" to give it. Mine is 2 BRAP BRAP's which is 50 to 60 FT LBS. Which has been confirmed via torque wrenches. Sure there are variables at times but close to consistent. If I give her "the beans" it will produce close to 600 FT LBS.
2016 Ford F250 XLT 4X4 6.2L
Hensley Arrow
07-08-2018, 10:18 PM
#30
Bit Socket question
I have two cordless drills that I use (Dewalt and Ryobi), both work great!
07-08-2018, 10:49 PM
#31
I use a hex drill socket driver. https://www.harborfreight.com/hex-dr...-pc-68513.html
I use the drill till the jack gets snug then turn the whole drill one or two turns. This way I can “feel” how tight the jacks are. The chuck is locked when not pulling the trigger.
Nobody wants to hear an impact driver in a campground. It’s the wrong tool for many reasons already mentioned.
2017 Rockwood 2703WS - Sold
2015 Keystone Sprinter 333FWFLS
2017 F250, 6.2 Gas, 3.73 Axle, 2902 lb Payload
If women don't find you handsome, at least they should find you handy!
07-09-2018, 03:51 PM
#32
As was I.
