Old 07-22-2015, 11:06 AM   #1
Black water tank on Rockwood HW296
Hello all. I'm new to the site. I just purchased a 2010 Rockwood HW296 last month and the family is loving it. I have used the forum to search about options for connecting the gray and black water drains and look forward to using some of the advice.
My question is, is/was there (supposed to be) a black water tank on my camper? I have looked under the camper and it appears the toilet goes right into the valve. I looked at the manufacturers specs and it says I'm supposed to have a 12 gal black water tank. The salesman was a complete moron, he said I have a cassette, which is obviously not the case. Did the HW296 have a black water tank in 2010 and mine was removed by the previous owner? Can someone help me get to the bottom of this?
If there is a tank where the hell is it? If there isn't what are the instructions using/maintaining the waste water system?
Thanks in advance
wsievers is offline   Reply With Quote
Old 07-22-2015, 01:41 PM   #2
vinmaker's Avatar
You are correct. The salesman is a moron.
You are also correct in that you cannot see a black tank amongst the dual grey tanks under the unit. You do indeed have a 12 gallon black tank. It resides under your toilet seat but above the plywood floor.
I hope this helps.
Vin.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 07-22-2015, 02:38 PM   #3
Thank you. After I posted I read the whole HW296 20pg thread and I kind of got that. The service guy was just as much of a moron because he thought I just drained out the valve. Do I need to do anything special to use it or maintain it? Does the tank cleaner work the same way as it would in a full size camper? Any tips or tricks would be welcomed.
Old 07-22-2015, 03:59 PM   #4
vinmaker's Avatar
That is correct. the maintenance required would be the same as a typical Travel Trailer. It is just that the holding tank is smaller.
Many here use a "geo method" which utilizes water softener. A search for that will produce lots of results. I simply use the blue thetford chemical to maintain my tank.
Other than that you will need a typical 3" sewer hose and possibly a blue tote if you wish to camp on W/E sites with no sewer.
Vin.
P.S. Welcome to the forum.
2015 HW296
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 07-23-2015, 12:00 PM   #5
Get a swivel stick (wand) and a Johnny chock. I try to camp with full hook that way I can clean the tank from the toilet down. You can get a hydro flush (back flush ) but you really don't get the pressure if something is stuck to the wall of the tank.
kinma13 is offline   Reply With Quote
Old 07-23-2015, 12:01 PM   #6
Oh and a garden hose dedicated for the sewer.
Old 07-23-2015, 02:17 PM   #7
vinmaker's Avatar
Good advice Kinma. I too use a swivel stick.
When I camp with only W/E and use a blue tote, I do this as a final step. I will dump the black tank into the tote, empty the tote at the dump station, and then flush out the black tank with the swivel stick. Then back to the dump station to empty the tote. A bit of work. But I really do prefer the w/E sites amongst the trees.
Vin.
2015 HW296
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 07-23-2015, 02:38 PM   #8
I would do that to but my TV is an SUV and there is no where to carry a tote other then in the pup and the DW would kill me
Old 07-23-2015, 03:21 PM   #9
bikendan's Avatar
this is what i've been using for 8+ years now.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 07-24-2015, 09:17 AM   #10
Vin.
I used the geo method and it worked great. Calgon make the liquid water softener. Flush the toilet a few time then add a cup or two of the softener, then I add a small bottle of Dawn dish detergent. Then flush the toilet a few more times. Do this before going on a trip and keep you valve closed. When you get where you are going you can empty it but if you have room in the tank drain it before you leave the camp grounds. This will clean your tank and coat the side walls so nothing sticks to them. This works well so you don't have to do it very often
Jim
07 Dodge 1500 crew cab with 20" wheels, 08 Forest River Rockwood Signature Ultra-lite 8280SS
"The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man."
George Bernard Shaw
oldtool2 is offline   Reply With Quote
black, black water, rockwood, tank, water, water tank
