Old 08-18-2013, 10:01 PM   #1
Blowing fuses
I had an issue with blowing my reverse power fuse when plugged into generator or 110V. Ends up I had the fridge set to the 12V setting, which caused the fuse to blow and then drained my battery. Figured that one out. Went camping this weekend. I plugged the power in at home to charge the battery ( does it charge the battery?) and that night we had no lights and I noticed the fuse was blown again. Replaced the fuse and its fine the whole weekend, even when I got home and plugged into 110V again.
Could it be that I perhaps had my truck plugged in at same time as power?
Any ideas?
Kawigreenguy is offline   Reply With Quote
Old 08-19-2013, 07:48 PM   #2
Jeep4Two's Avatar
Plugged into the truck while on shore (or genny) power might do it. Not sure why the fridge on 12v when on shore power is blowing fuses.
I accidentally left my A126 fridge in 12v last weekend and the only issue was I heard the converter fan from time to time. Didn't discover my error until hitching up and going to switch to 12v before hitting the road.
Jeep4Two
2011 FR Rockwood Premiere A126 Hard Side
TV=2011 Jeep Wrangler Sahara 2 Dr
Reese 66065 WDH, Curt WDH Shank #17120
Prodigy P2 Brake Controller, Mopar 7-pin Harness
B&M Transmission Cooler (#70268)
Jeep4Two is offline   Reply With Quote
