Old 10-16-2011, 04:25 PM   #1
daydreaming about camping
jeeplj8's Avatar
blowing out water lines - how do I get water out of water heater/holding tank?
supposed to get our first frost one night this week. So I blew out all the water lines on the pop-up. I can hear water gurgling in the hot water heater tank, how does one completely drain it?
I also noticed there is about 1 inch of water in the fresh water tank that is below the petcock drain valve. Again, how do you get it out?
Thanks for the help.
2013 Coachmen Freedom Express 320BHDS pulled by a 2005 F250 King Ranch CC
A rainy day camping is better than a sunny day at work.
jeeplj8 is offline   Reply With Quote
Old 10-16-2011, 04:27 PM   #2
Did you remove the drain plug? If so, I am not sure how to remove the remaining water.
Dave
Currently trailerless.
2014 Silverado Double Cab 1500 5.3L V8 w/3.42 Axle Ratio Tow Vehicle
Sold: 2012 Rockwood A122 Hardside Popup
daveinpickerington is offline   Reply With Quote
Old 10-16-2011, 04:29 PM   #3
jeeplj8's Avatar
Dave
There is a drain plug in the hot water heater? I felt around the thing but could not find one.
Old 10-16-2011, 04:38 PM   #4
Open the outside cover and at the bottom of the tank is the drain plug.
Old 10-16-2011, 04:45 PM   #5
Here is a photo I found on the internet.
Draining an RV Water System
Old 10-16-2011, 04:58 PM   #6
3 Happy Campers's Avatar
A little water in the bottom of hot water tank or the fresh water/waste water tank is completely fine.
Itís been a long time since high school physics class but hereís the reason why.
Damage comes from the water expanding in a confined space while freezing.
Water freezing in a water line can cause the line to bulge & possibly rupture.
This is most likely going to happen @ a low point (dip) in the line or @ an elbow.
Water freezing in a faucet will cause the parts in the faucet to expand against each other.
When the faucet thaws thereís a gap & you have a leak.
Relax, A little water in the bottom of a LARGE tank will not expand enough to cause any damage. You will never be able to remove all the water.
Furthermore a small frost will generally not cause any freezing issues.
You have to have a continuous below freezing temp for any damage to take place.
For most of the US (for the next couple weeks) just draining/blowing out the lines & leaving faucets open will prevent any damage.
Iím in northeast PA & just blow out the lines after each use clear into Dec. Have been doing this for 20 yrs with four different campers. Never had an issue.
Dave, Judy & Daisy May
Perkasie, PA
2010 Sierra 356RL
2011 Silverado 2500 4WD, LT, Ext Cab, LB
Duramax 6.6L V8 Turbo Diesel
Allison 1000 6-Speed Automatic Transmission
3 Happy Campers is offline   Reply With Quote
Old 10-17-2011, 06:26 PM   #7
flyrotor's Avatar
The drain plug is also the heater anode rod, remove and the tank empties.
flyrotor is offline   Reply With Quote
Old 10-17-2011, 07:26 PM   #8
jeeplj8's Avatar
thanks daveinpickerington. the irony is before the dsys of the internet, I would have kept looking at it till I found it.
3 happy campers: one of concerns with plastic tanks is that the freeze may begin to weaken and age the plastic, but i take your point, not going to be cold enough here to do any damage.
Old 10-18-2011, 12:41 AM   #9
If you winterize with rv antifreeze(the pink stuff) as we have to in the frozen north, any water left in the grey and black tanks will be diluted with antifreeze as you run it through the water lines. Anything left in the fresh water tank would be minimal and freezing won't harm the tank. The hot water tank is the same, after removing the anode rod or drain plug there won't be enough water to do any damage. Been doing this for about 18 years on different trailers with no problems.
Ray
'04 Dodge 3500
'11 Flagstaff 8528RLWS, Hijacker 16k slider
HTR member Nights camped 2010 -115, 2011 -40 , 2012 -41, 2013 -86,
seatosea is offline   Reply With Quote
Old 10-18-2011, 07:14 AM   #10
camper007's Avatar
Perhap's after removing water heater plug and anode rod, blow air throuth the line's. The drain plug is the rusty one at the bottom.
camper007 is offline   Reply With Quote
