Old 06-12-2017, 02:18 PM   #1
Bolts
Noticed that a couple nuts n bolts are missing from the bathroom walls that hold them to the Hinges. Can't find them at home depot or lowes. Any suggestions? 2015 rockwood hw276
kinma13 is offline   Reply With Quote
Old 06-14-2017, 09:31 PM   #2
I hate the bathroom wall mounts. I'm always tightening them each trip out. This post weekend I put toothpicks in the hole to tighten it up. Mine is just screws though that loosen. Can't even think where there are nuts and bolts
2016 HW296
2016 Ford F-150
tigger68 is offline   Reply With Quote
Old 06-14-2017, 09:39 PM   #3
Yes the screws that hold the hinge to the main non moving wall on mine were also loose I too used toothpicks and wood glue. But I'm talking about the bolts that you use for the wall that moves (with the mirror) the bolts hold the hinge to the wall that flips up. Both walks. But I did find some that should work but the head on the bolts are small in diameter and they are about 2 washer to short.but they should be fine. I'm bolting and using lock tight on all the acorn nuts. Hopefully that will keep them from coming loose again.
Old 06-15-2017, 06:00 AM   #4
Please take a picture when your done. I might need ideas before long
2016 HW296
2016 Ford F-150
Old 06-15-2017, 07:12 AM   #5
Will do. It will be next week cause it's raining where I live but we go camping next weekend the 23rd.
Old 06-15-2017, 07:14 AM   #6
When they fall out I can find the acorn nuts, I'm thinking the might bu making their way to the shower floor and going into they grey tank.
Old 06-15-2017, 07:36 AM   #7
I have no idea what bolts and nuts you're talking about in your case, but I do suggest using nyloc nuts in any application you can, both inside or outside the rv, ... they WILL NOT loosen and fall off the bolt, ... vibration, twisting, ect., can cause just about any screw in an rv to loosen, I use machine screws and nyloc nuts as replacements ever time I possibly can, ... the link below is a sample from Lowes, .....
https://www.lowes.com/pd/Hillman-1-4...ck-Nut/3058721
fella10 is offline   Reply With Quote
