04-06-2014, 06:57 PM
Brake controller
Hi all, ? We tow with a 1999 jimmy and was wondering has any one added a brake controller to their unit. Our pop up has electric brakes, I want to add a braking system. Truck does have tow package, will I have to cut into the system or plug and play. I do work on cars on the side and I am just trying to do my home work.
Sent from my LG-P769 using Forest River Forums mobile app
04-06-2014, 07:09 PM
chicagoslick
Try checking out all the great information on Etrialer's website...they are easy to install and setup...I prefer the Tekonsha Prodigy Line, but all will work for what you are doing...
GMC Jimmy Brake Controller - 1999 | etrailer.com
Gary, Tonia, Baile, Summer and Otis our Boston T.
Flagstaff 27RLWS Emerald Pkg
2015 Ford F150 King Ranch FX4 Max Tow 3.5EB, 3.55
Equalizer 4 WDH, 1,200 / 12,000Lbs
04-06-2014, 09:53 PM
Most GM vehicles with a tow package have a four wires bundled to the right or left of the steering column, just under the dash.
Lt Blue is the vehicle's brake switch input to the controller (has voltage when brake pedal is pressed)
Dk Blue is the output from the controller to the rear 7-pin plug for the trailer brakes
(output voltage is dependent upon the controller settings)
Red is hot at all times through a brake fuse in the fuse panel
Black is ground.
And I'll also put a plug in for Tekonsha as having some of the best controllers on the market.
04-06-2014, 11:49 PM
99 GM should be equipped with a connecter port on the fuse relay panel for the brake controller
just connect break controller wire to the plug adapter and plug it in you are done. Here is a Web link for the 99 S10 http://www.etrailer.com/multi-produc...2620&hunter=bc
Sent from my SCH-I545 using Forest River Forums mobile app
2007 GMC 2500 Duramax Crew Cab LB
2008 5th Wheel Cardinal 36LE
04-07-2014, 08:41 AM
Even if you don't have the wiring it's very simple to setup. Etrailer has great documentation for wiring a controller in just about anything - a couple of fuses, some wire, and you're done.
- Randy
1975 Westfalia (VW)
2014 Rockwood A122
04-07-2014, 08:01 PM
what settings do you set your P3 brake controller on? my unit goes up to 14 / that still does not lock rear wheels/I set mine on 10 I am sure we all set them different / just want to get other feed back from others/ thanks
2014 A122s rockwood 2014 jeep grand Cherokee v6 290 hp 4by4
04-07-2014, 10:01 PM
I have a truck with the integrated brake box now and have it all the way up because I am pulling a 42 ft 5er. For the old truck and TT I th hunk I had it a little more that have way.
04-13-2014, 08:03 PM
Ok, got a brake controller unit, pod 80500 for 18 bucks of eBay, still in box!! Can't wait to get it hooked up.
